Drifting Discuss Drifting and drifting techniques here.
PowerSteering...
Old Dec 12, 2008 | 09:56 PM
RE TurboII's Avatar
Meow
PowerSteering...
okay so my new car has a PS rack, PO removed the pump and everything and installed a single main pulley. i heard FD's use single pulleys, anyone confirm? if this is true would i be able to use a FD pump with my FC PS bracket? what would be required to maintain the single pulley + PS? craps giving me a headache
Old Dec 13, 2008 | 11:14 AM
Ranzo's Avatar
pics? not sure what you are talking about. FC only has one PWS pulley
Old Dec 13, 2008 | 01:36 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
I guess he's talking about the idler pulley which you could probably delete if you bought a smaller belt.
Old Dec 14, 2008 | 04:19 PM
RE TurboII's Avatar
Meow
Old Dec 14, 2008 | 07:07 PM
TechTrix's Avatar
both the fd and fc have seprate pulleys for the ps and ac. you just need to take the ps pulley itself and bolt it to your new crank pulley.(hopefully it will fit) changing it to a multi rib belt like an fd, or your new pulley set up will be a pain, with no gain...
Old Dec 24, 2008 | 05:55 PM
ncastrignano's Avatar
RE for life
from the pic it looks like the previous owner converted it to a ribbed belt so what u need to do is just find original FC pullies and put everything back and u will be fine. the original pullies are just v-belts.
Old Mar 23, 2009 | 11:05 PM
RE TurboII's Avatar
Meow
update: gonna run electric powersteering, pump should be here wednesday i hope? (chance.....)
anyways anyone know the thread pitch of the actual racks feed and return line? im gonna run a cooler in-line with the return, should be buttery. if anyone knows holler
Old Mar 24, 2009 | 12:25 AM
NoPistons!'s Avatar
Tango Down
Well, if nobody helps you, go to your local hardware store. Bring your fittings for the ps rack with you. Start reaching into those nuts and bolts trays and thread **** on. You'll find the right pitch. I've had to do this ALOT.
Old Mar 25, 2009 | 04:43 PM
driftfcbuckey's Avatar
RX7-Factory
Originally Posted by NoPistons!
Well, if nobody helps you, go to your local hardware store. Bring your fittings for the ps rack with you. Start reaching into those nuts and bolts trays and thread **** on. I've had to do this ALOT.
don't we all....
Old Mar 25, 2009 | 05:07 PM
Sindregutt's Avatar
why dont you just use your
Metric threads are easy to measure with that thing above (whats the name again?)
Old Mar 25, 2009 | 09:57 PM
RE TurboII's Avatar
Meow
I dont have one of those thing-a-majig-e-wiggys
but i got the pump today (thanks chance aka slidealliance)
im just gonna go to a place the sells earls fittings and have them check and give me whichever ones i need. ill also be posting a write up in some other forum for those who are interested in it.
Old Mar 26, 2009 | 09:54 AM
87base RX-7's Avatar
caliper
Old Mar 27, 2009 | 09:54 PM
RE TurboII's Avatar
Meow
question:
My rack has 3 holes, can i plug one of them? which one is Feed and return and which one can i plug, i have the pump mounted already and by next week should have all the fittings and lines done
Old Mar 27, 2009 | 10:18 PM
Tatakai's Avatar
lemme know how it goes bro
greggtr
Aug 24, 2007 02:41 PM
-Ryan-
Aug 1, 2006 07:14 PM
sleejay
Jul 7, 2005 09:27 PM
ItalianFedRotary
Jul 5, 2002 11:08 PM
