When do I need a RRFPR
Old May 17, 2002 | 11:52 AM
SPOautos's Avatar
Hey, where did my $$$ go?
I have a questions for you guys. I know this isnt a single turbo questions but most of you guys have been thru this so I thought I might could get some good answers here.
At what point is a RRFPR needed? Is the stocker good for a certain hp or boost level or what? I just need to know at what point I need to start looking into upgrading it.
Thanks guys,
STEPHEN
Old May 17, 2002 | 12:08 PM
Wade's Avatar
You never "need" it. It's just an option (if combined with a serious fuel pump) to take if you want more fuel out of your existing injector setup.
Wade
Old May 17, 2002 | 01:00 PM
BOOSTD 7's Avatar
Persona non grata
I agree. I don't think you should ever use one ... assuming you have proper engine management. Just let the ECU handle all the fuel requirements in the proper way.
Old May 17, 2002 | 11:08 PM
weaklink's Avatar
Resident Retard
Stephen, I had this same question since I am going single. What I will end up doing is I got an upgraded fuel pump, bought a set of spare injectors and will have the primaries cleaned, calibrated and balanced and the secondaries likewise, but bored to 1300cc. I will control it all with the PFC. (thanks to DCLIN).
Old May 17, 2002 | 11:20 PM
sinfestboy's Avatar
what the hell do you mean by RRFPR?!?!?!?
Old May 17, 2002 | 11:35 PM
ludeowner's Avatar
Rising Rate Fuel Pressure Regulator
Old May 18, 2002 | 12:50 AM
sinfestboy's Avatar
ok. now that I think about it, i cant believe i couldnt pick the "FPR" out of there.
Old May 19, 2002 | 06:54 AM
We forgive you ..only because of your JLO pic
Old May 19, 2002 | 11:39 AM
Directfreak's Avatar
I am a Jeeper Now.
Wade
Also Highly recommended for Blow-Through Carb setups.
Node
Oct 14, 2006 04:06 PM
NZ_87_TURBO
Mar 29, 2006 09:11 PM
seanrot
22
Jul 27, 2004 12:19 AM
SPOautos
Rotary Car Performance
May 18, 2002 12:35 AM
machinehead
Dec 11, 2001 06:41 AM
