You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join RX7Club.com today!
Hehee...i be watching you Gus when you flick the switch of your "little" monster Hope it sounds really mean Then we go to the dynoroom and make some numbers Looks good anyway
/Lasse
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on RX7Club.com!
just did some dyno pulls and the car put down 595whp@22-22.5psi, peak hp at 7160rpm, having some problems with boost, it wont hold up.
Ill post some logs for you when i get home and maybe some of you gurus can help me out
i just passed 100+ dyno pulls with this engine
Ok, here are a log from one pull.
green line = boost (in bar)
red line = backpressure (in bar)
As you see im losing boost... is the backpressure causing this?
im using the small valve seats (28mm) and their 60lb/inch spring (the hardest one)
It is set up like this (http://synapseengineering.com/smf/in...d57&topic=97.0
Im also using a HKS HVC (IV) boost controller, i can't say im very familiar with it.
Oh, im still one the 3" exhaust.... :/
595WHP RX-7 Borg Warner s475 E85
I don't have any experience with your wastegates so i have no clue about them...
I would try disconnecting them and setup some sort of boost limit on your ecu or stay very alert and watch the boost and see if you can get more boost without it falling off..
I don't believe you have to much backpressure. you have roughly 28psi back pressure with 22.5psi boost. That's not bad at all...
Thanks for input..
i've got some more combinations to try on the wastegates, they've got some kind of internal boostcontrol letting you choose different ports for different boost. Ill try the highest setting and just run it on the springs..
please post up what you find out with the differant combinations on the gate as I am running the same and getting ready to turn the boost up for tuning....
FD street-drag 600hp club
RX3 drag project
Hmm appears to be losing boost at the end of the pull. Does appear to be backpressure maybe blowing the gate open. Does your unit have the 96mm turbine wheel and 1.32A/R housing?? Most of the cars I have worked on with that turbo don't have much of a problem. Also have you got a restrictor on the oil inlet on the turbo?? I have worked on 2 FD's running Borg 475's that ran restrictors...killed the turbos less then 100 miles. Borg's like plenty of oil...
93 RX-7 TT
Built 13B
Greddy Exhaust, AFC, Greddy manifold...etc
Forced Inductions S70 Borg Warner Silver Billet turbo
