Power FC Will a 16 bit harness work on a power FC?
I saw that the 16 bit engine harnesses run a bit cheaper on rhd japan. Will it work with the PowerFC in a USDM car?
Trending Topics
hell yea theres difference
i have a 2000 fd motor in my fc and i had it running on a 93-95 ecu and wire harness then i got a killer deal on a series 8 ecu , wire harness and map sensor , by the way the map i got from japan2la great seller by the way.the car revs out cleaner responds to minor fluctuations diffrently and is alot quicker. also it doesn't throw flames as much i dunno why .and it doesn't pop and after run like how t2's and 93-95 's do when you get on it and let off, just a smoother run, i'm guessing because the ecu is more refined and has faster processor and more resolution.
16bit =Much faster than 8bit.. This is how Mazda was able to make 280PS on the 99 and up GF-FD3S RX7's.. Most people think its just the turbos...The turbos hold boost better and the faster electronics helped make 20+ more HP from previous setup..
thewird
Frisky Arab
13
Aug 18, 2015 05:30 PM
