help with n/a s4
Old Nov 24, 2008 | 08:24 PM
thecrow's Avatar
DETROiT RiOT RACiNG
help with n/a s4
so im still new at buying used engines, but mine blew up. there is an engine for sale semi locally that has 60 thousand miles on it ( thats what the guy claims) but it has been sitting inside for 6 years. how much is it worth? and how likley is it that nothign has gone bad? or is it very likley that everythign is bad? Thanks alot for your help
Old Nov 24, 2008 | 11:11 PM
mar3's Avatar
Administrator
Sitting INSIDE sounds good...INSIDE a bag INSIDE even better. As for a price, I'll let the GSL-SE and 2ndgen guru's take a gander for you...
Mario III
Old Nov 25, 2008 | 12:27 AM
rowtareh?'s Avatar
I Dislike Everything
If the motor starts up then it should be fine. However have a compression test done on the motor to make sure that everything checks out. Check for oil leaks as well. Usually you can tell the truth on a motor by checking the belts (that's how I do it at least). If it looks destroyed or really worn out, it's usually a false statement by the seller.
Or is the motor in a warehouse/shop just sitting on a pallet?
If the motor is blown, you should move on to the next one that you can find.
rxlevi7
Sep 26, 2015 07:28 AM
mulcryant
Sep 9, 2015 05:24 PM
