Rotary Drag Racing The place to post your racing stories and info
aeromotive A1000 stalls sometimes- need tech help
Old Nov 23, 2008 | 10:17 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
I have noticed my a1000 is starting to stall. And when i tap it once it will turn on. what could it be bad pump, wires, what about premix? anything problems like mines that you guys have gone through with these pumps let me know what u did to fix it.
Old Nov 23, 2008 | 10:22 PM
ultimatejay's Avatar
If you have to tap on it to get it to run then your pump is bad. It's no different than hitting a bad starter motor to get it to turn over. Just make sure your power and ground is good. Also make sure your filter is not plugged and you have a good clear return fuel line. If the filter is clogged or you have a bad or no return line then your pump will have to work overtime and wear out premature.
Old Nov 24, 2008 | 01:19 AM
RoTaRyBoYz's Avatar
InsaneRotaries.com
one major problem most people over look is how some of these pumps have to be installed. That pump is gravity feed, that means its not design to "suck" fuel like the stock pump. Make sure your pump is mounted lower than your fuel tank, that way it gets a constant supply of fuel to keep cool & to maintain proper fuel flow. If not, then you could be wearing down your pump prematurely which may be why you have to hit your pump for it to work.
I used that pump for 3 years in my 1st gen with no problem.. Now its being used in another turbo 1st gen with no problems. Good mounting location, good ground, good filters & your're good to go!!
If my friend is reading this post... Don't forget the return address of the pump I loaned you a few years ago you bastard
Old Nov 24, 2008 | 08:42 AM
MODERATOR
Yeah power and ground are solid, i have it mounted level with the bottom of my tank like the owners manual said because it a gravity pump, and my aeromotive filters are superb.
I guess my pump is taking a dump on me, by any chance do you guys think weather could be the problem i have notice it only does this when i leave my car outside overnight.
Old Nov 24, 2008 | 11:30 AM
turboR1's Avatar
ErnieTKiLLA
i have gone thru many problems with aeromotive the eliminator pump a lil bigger then the a1000... even sent it back to the company to fix few times.. and do you know how i fixed the problem? I used a different pump..
Old Nov 24, 2008 | 11:34 AM
13B-RX3's Avatar
7s before paint!!!
What micron filter are you running on the inlet and outlet?
Old Nov 24, 2008 | 04:06 PM
MODERATOR
inlet 100 icron outlet 10 micron
would aeromotive really fix these pumps
Old Nov 24, 2008 | 04:44 PM
hondahater's Avatar
spending too much money..
Some people seem to have good luck with these pumps but many don't. I've heard issues with these pumps can include the problems you are having also if the feed lines aren't big enough (10an) it can choke the pump. If you continue having problems you should try the 044. If you are around kilo's shop when he's dynoing my car this week you should see (hopefully) the 044 support 500hp... of course that's with the help of a boost a pump.
Old Nov 25, 2008 | 09:17 AM
MODERATOR
oh we like the a1000 and their production line , there s no doubt about its performance. I am not too fond of the 044 but everyone has their own opinions . We have success with aeromotive and we will continue with them.
As far as my feed line -10 an all the way , its just my pump is taking a dump on me i guess. I do daily drive my car out here so too much usage can also wear it out.
I will be there friday to help out with some things but i will see what it has....WHO KNOW I MIGHT DRIVE IT BEFORE YOU DO! lol jk
Old Nov 25, 2008 | 09:44 AM
Busted7's Avatar
Will work for horsepower
If the motor on the pump uses brushes there probley the cause, and when you tap it they make connection!
Old Nov 25, 2008 | 10:19 AM
hondahater's Avatar
Hey be my guest man, just no blowing it up
Old Nov 25, 2008 | 12:47 PM
london's Avatar
aeromotive pumps
I have tried about 4 of these pumps and once they sit too long the magnet unsticks inside the pump and the two half of magnets grab the armature and the pump does not work ,cant even turn,we opened one and stuck back the magnets but after a while same thing happened ,remember these pumps have gas flowing inside all the electrical componets,my advice to you is these pumps are worthless.i am using a weldon for the last 5 years and never had any probs.
Old Nov 25, 2008 | 03:23 PM
MODERATOR
Yup the only thing i can think of is the brushes sticking, or worn out springs . Either one could be the problem i wil call aeromtive to see what can they do about this.
As far as it getting stuck (3 times now) in the matter of 2 months on daily driving i can only imagine that could be the problem.
Old Nov 25, 2008 | 03:46 PM
zinx's Avatar
_________________________
I had an A1000 stop working during a cruise a year ago. I think it may have gotten too hot. After it sat for 10 minutes or so, it fired up and i drove it home. I threw it away and ordered another one. I didn't like the thought of it just dying on me like that.
Old Nov 25, 2008 | 04:49 PM
turboR1's Avatar
ErnieTKiLLA
I had that same problem out of several with aeromotive. My magnets came apart as well. Cost me a motor or two. When I called aeromotive they told me the glue they were using to hold the magnets doesn't last when it was exposed to gasoline. thats great.. and then they made me pay for an updated case that was "suppose to fix the problem". that and the pump doesn't flow what its suppose to at high fuel pressure and it even starts dropping pressure which could lean you out real quick. I wouldnt trust it over 400rwhp.
Old Nov 25, 2008 | 05:38 PM
rex3's Avatar
E85+Boost+Rx2=zoom zoom
Is that your car on ebay forsale?
Old Nov 25, 2008 | 09:00 PM
MODERATOR
yes sir it is, man its stuck at 6k no one knows what we have to go through to build a reliable , high horsepower, and worthy rotary nowadays. I been getting pms and emails of people wanting me to trade worthless cars and lowballs that are so low they hand like that little midget from austin power' movies.
Old Nov 25, 2008 | 11:40 PM
With the economy the way it is right now, that's all your going to get is low ballers and traders. Not a good time to sell, but a good time to buy.
So regarding the Aeromotive pumps..... what I got from all this is that they are pieces of ****...?
Old Nov 26, 2008 | 06:25 AM
rex3's Avatar
I give you props it's a beutiful car. Good luck with the sale
QUOTE=El Nene 7;8750718]yes sir it is, man its stuck at 6k no one knows what we have to go through to build a reliable , high horsepower, and worthy rotary nowadays. I been getting pms and emails of people wanting me to trade worthless cars and lowballs that are so low they hand like that little midget from austin power' movies.[/QUOTE]
Einheri
Oct 7, 2015 12:23 PM
