West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
rims rims rims
Old Nov 19, 2008 | 05:48 PM
84 rotary rocket's Avatar
rims rims rims
i've been proactive looking around for some rims for my 1990 trubo II, i have put on a suspension on it and the left fender rubs. i really wat to get some fat tires but i don't beleive they fit. what can i fit on it? i want at least 17's by 8 hopefully
Old Nov 19, 2008 | 06:13 PM
FC_EDDIE's Avatar
You can do a 17 x 10 or 18 x 10 in the back and 17 or 18 x 9 in the front no problem on stock fenders ...stretch the tire (245/40/17 or 18 and it'll look great in the back and a 225/40/17 or 18 in the front.
Focus on the right offsets though
Old Nov 19, 2008 | 07:07 PM
finishline's Avatar
Not Even Foo
maybe ask your locals.
https://www.rx7club.com/nw-rx-7-forum-33/
Old Nov 19, 2008 | 10:41 PM
namelesspenguin's Avatar
chasing those red numbers
Originally Posted by finishline
+1 (great info in that thread)
or, go Gram Lights 57s 17X9.5 +22 (f) 17X9.5 +12 (r) and stretch the tires like edbltx7 said...225 in front, 245 out back.
Old Nov 20, 2008 | 09:58 AM
fc3s91's Avatar
R.I.P Mark( Icemark )
I fit a 275-35-18 + 32 in the rear and 245-40-17 +35 in the front . With No fender mods. Check my sig.
Thanks Robert
Old Nov 20, 2008 | 09:59 AM
fc3s91's Avatar
Thats also a 9.5 in the rear and 8.5 in the front.
Thanks Robert
Old Nov 20, 2008 | 10:39 AM
FC_EDDIE's Avatar
Thanks Robert
GANGSTA!
Old Nov 26, 2008 | 07:46 PM
but how much does it matter with the thickness of the tire? i know i want to go 8.0 in the front would it make that much of a difference is i run 8 in the back as well? with a stock turbo (apexi ecu, 3' exhaust, air intake)
Old Nov 26, 2008 | 08:02 PM
Brismo7's Avatar
6 Speed FC
get 9 inch minimum. 9 inch can fit up to 275. I run 255's with room to grow on my 9 inches.
Thats right baby, i'm 9 inches
Old Nov 26, 2008 | 08:20 PM
-=Lil Red=-'s Avatar
R.I.P. Guitarjunkie28
^ 9" W I D E, ask andrew he knows
Old Nov 26, 2008 | 08:23 PM
AcidAngel7477's Avatar
We're All Fkd..
wow..
:AA:
Old Nov 26, 2008 | 08:37 PM
fc3s91's Avatar
Here's what 17-9 in the front looks like. Tire size 245-45-17 v710.
Thanks Robert
Attached Thumbnails rims rims rims-img_0915.jpg   rims rims rims-img_0911.jpg   rims rims rims-img_0914.jpg   rims rims rims-img_0913.jpg   rims rims rims-img_0912.jpg
Old Nov 27, 2008 | 12:07 AM
KeloidJonesJr.'s Avatar
strictly business
RPF01's FTW
What are those 5 spokes?
Old Nov 27, 2008 | 09:56 AM
fc3s91's Avatar
Rpo1 enkie
Old Nov 27, 2008 | 12:15 PM
Battle Cat's Avatar
Space cadet
it doesnt matter if its 8 in the rear, you can even go 9.5(or bigger) in the rear on your set up..
there wont be any power loss, only if you go 18s or bigger..
other than that itll be fine. i ran Honda S2k rims 16x7 front and 16x8 rear on my N/a and it was great!!! felt better., and now im running stock fd rims 16x8 all around on my turbo, but there not wide enough for the power im goin to be pushing.
the wider the better.
anything along the lines of x8 or up to x9.5 or x10 is great
Old Nov 29, 2008 | 01:11 PM
alright, besides from the sizes, where should i get them? when i go to tirerack.com it wont let me pick sizes. my budget is around 1300 or so... i don't want togo much higher... i was thinking O.Z. that are 17x8 all around.... but i wouldn't mind 17x9 in the back.. or 18x9.
Old Nov 29, 2008 | 02:06 PM
JustinStrife's Avatar
Meth Head
Definitely get at least 9" wide in the back, especially if you're turboed. You're going to want the extra tire patch on the ground if possible for maximum traction. Plus it looks sexy as hell seeing 275+ wide tires out the back of these small cars.
Old Nov 29, 2008 | 02:11 PM
Battle Cat's Avatar
Space cadet
+1 thats sooo true,
you can try RB motoring.com, they have some pretty sick wheels,
Old Dec 1, 2008 | 12:24 PM
sakura_FC's Avatar
whatever you liiiiikkkeee
Good info!
Old Dec 1, 2008 | 04:44 PM
275+ 35mm off set? i'm sorry i'm some what of a novice at this.... i know what 18x9 is and such but what is the whole tire lingo?
Old Dec 1, 2008 | 07:41 PM
275 tire width, +35 wheel offset on a 9in wide tire.
Old Jan 3, 2009 | 11:46 PM
i ordered some rims, oz ultraleggeras 17x8 and they did not fit, they where less than a centermeter away from the springs and the tires would had rubbed. so i got some 17x7 and the biggest i was able to fit is 215's in the front and 225 in the back. you cant fit any bigger than 225 in the back becasue the rim is only 7 inches wide and the tire is to wide for the rim.
Old Jan 4, 2009 | 12:09 AM
Miata_mx5's Avatar
Wangan Nasty
Run 17 x 9 in the rear and 17 x 8 in the front. If you are not able to fit it, you are doing something wrong. You need to play with the alignment, tire profile, sizes, till you get it right.
It's been fitted on an FC all day long. Worst case is you need to roll/pull fenders.
Old Jan 4, 2009 | 12:15 AM
MaczPayne's Avatar
Mac Attack
255 all around!! Save those tires, rotate em!
Old Jan 4, 2009 | 12:56 AM
Michael Knight's Avatar
Don't hassle the Hoff!
5 Zigen FN01r-c's FTW! Fr- 17X8+35 225 R615's, Rr-17X10+35 255 R615's. Both had room for a little more rubber. I've got a buddy that can get them for $under 760 new in Corona. A little over 1k for Falken zenis r615's and rims/caps/n'stuff mounted/balanced.
Attached Thumbnails rims rims rims-rims1.jpg   rims rims rims-rims-2.jpg   rims rims rims-rims3.jpg   rims rims rims-rims4.jpg
