new to rx7
Old Nov 19, 2008 | 05:03 PM
rx7maniac95's Avatar
Newbie
new to rx7
do they come stock with an intercooler??
Old Nov 19, 2008 | 07:25 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Only Turbo Models
Old Nov 19, 2008 | 08:17 PM
Newbie
MD
well im either gettin a 1993-1995 soon nd i kno they come turboed so they do come with an intercooler stock? nd should i make a bigger 1 and upgrade priority?
Old Nov 20, 2008 | 02:15 AM
ThoRx7's Avatar
well, 93-95 all came out of the factory turbo.. and yeah with an intercooler also because of the turbo produce so much heat that the intercooler is there to cool it down.. and im not so sure what u mean by bigger 1?
Old Nov 20, 2008 | 09:23 AM
Aaron Cake's Avatar
Engine, Not Motor
Please speak in completely sentences without shorthand. You'll find you'll get much better answers.
Yes, all turbo RX-7s (with the exception of the turbo 1st gen) have a stock intercooler.
The stock intercooler is fine for running stock boost levels. On the FD, you'll find that the intercooler pipes are plastic and tend to expand under heat. If you intend to drive the car hard, upgrading those to stainless/aluminum will help. Next you'll find that the weak point has been moved to the plastic intercooler end tanks. At which point there are drop in all-metal stock replacements, or larger FMIC kits.
If you intend to upgrade the car, then an intercooler upgrade is required. Otherwise, the stock cooler does fine.
Th0m4s
Feb 26, 2019 02:04 AM
