Series 5 Turbo upgrade
Old Nov 18, 2008 | 06:16 PM
rotorykiwi's Avatar
Classic RX7
Question Series 5 Turbo upgrade
Is there a way to upgrade the factory S5 turbo by changining or modifying the compressor \ housing and retaining the internal wastgate housing? Turbinetics used to make a bolt on high capacity compressor which mounted to the wastgate housing but they no longer do this. What options do I have if I want to retain and upgrade the original turbo?
Old Nov 19, 2008 | 10:13 AM
Aaron Cake's Avatar
Engine, Not Motor
Yep. Most T4 stuff fits, but regarding the wastegate you will need to get creative.
Old Nov 19, 2008 | 05:08 PM
t.moore's Avatar
ya the series 5 motors and upgrades are good cheap upgrades.
Old Nov 20, 2008 | 06:47 PM
rotorykiwi's Avatar
Classic RX7
Originally Posted by Rot--Head
i got it offer me ill send the pics its mint
Why are you selling your S5 turbo? Has it been modified with bigger impellors (on the compressor side) to pump a higher CFM than factory standard? What boost has it been putting out and what is its max CFM. Send me the photos of your S5 turbo to: carltonc@paradise.net.nz
Old Nov 20, 2008 | 06:50 PM
rotorykiwi's Avatar
Classic RX7
Please translate what T4 means as I am relatively new to all this. I'm trying to find "bolt on" solutions without going down the custom machining route.
Old Nov 21, 2008 | 10:26 AM
Aaron Cake's Avatar
Engine, Not Motor
T4 is a size of a family of turbos. You're not going to find any bolt on stuff. At the very least, there are some modifications to make this stuff fit. Even the direct bolt on requires the turbo to be balanced.
If you want an off the shelf solution, check out BNR turbos.
Keep in mind that any sort of turbo upgrade requires upgrading the fuel system and intercooler.
C. Ludwig
Jan 30, 2019 06:31 AM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
