Microtech 12a turbo leading ?
Old Nov 17, 2008 | 04:51 PM
bassrotor's Avatar
bassrotor
FL 12a turbo leading ?
hello fellows I'm running a lt10 , with stock 2nd gen coil pack, on the microtech winring is on the leading coil
yellow/black to neg side
yellow to neg side when using 4 coil, but and 2nd gen there is only on coil with 2 outlet my question is can I jump does 2 wire the comes from the microtech to connect or there is another way,
thanks for your help,
Old Nov 26, 2008 | 05:07 PM
rx72c's Avatar
Top Answer: 1
When you bought your lt10s. DID youbuy it with an x4 box?
Once you answer this question i can help you sort out your coil packs.
Old Dec 2, 2008 | 09:03 PM
bassrotor's Avatar
bassrotor
Yes the lt-10 and x4 box, the problem the I had when I did the installetion, I though the I can put the 2nd gen coil pack, witch i did but the leading side you can only use one wire the comes from the micro, I din't know the you have to use 4 coil or use the 2nd gen trailing coil, but thanks for your respond I have my system working fine know I have some Pic on the 1st gen section
Old Dec 2, 2008 | 09:52 PM
rx72c's Avatar
Top Answer: 1
If your car has the x4 box you can only use 4 seperate bosch coils or 4 mazda 2nd gen trailing coil packs that have had the ignitor stripped off them.
MoTeC
Sep 10, 2015 07:58 PM
Josh83rx7
Sep 2, 2015 05:57 PM
rx7brandon
Aug 16, 2015 10:55 AM
Wolf_
Aug 11, 2015 04:23 PM
