Rotary Drag Racing The place to post your racing stories and info
Inner axle cup recommendations
Old Nov 12, 2008 | 03:47 PM
Bacon's Avatar
IRS 4 Life
So yet another trip to the track has ended in carnage, this time the driver’s side inner axle cup decided to fail. I had replaced the passenger’s side last year after it broke the night before pinks. I’m guessing the best avenue would be to get some new ones from ray, then have them cryo treated. Just wondering if there’s a better option…. Aside from ErnieT brand axles for 1900$, I’m only making 465rwhp but I’m wondering if it makes more sense to start saving now and fix it right for the last time, just hard to swallow a 2k fix. Would heat treating be better than cryo since cryo typically better for wear applications?
Thanks for any insight. I should known after tec failed me for having 2 mo expired seatbelts I should have called it a night.
Old Nov 12, 2008 | 06:03 PM
twokrx7's Avatar
Need more sleep
Does that axle damage take out the clutch type diff as well?
Cryo treating should reduce residual stresses, reduce slip planes, and some other grain structure imperfections which improve toughness and fatigue properties. By how much is under much debate without A/B testing.
Old Nov 12, 2008 | 11:51 PM
AnthonyNYC's Avatar
Stay tuned...
Mine keep breaking also. They lasted all season on 30psi@500+ hp but on 35psi around 600HP they are just snapping. Last 2 events were a waste of time. I think I'm just going to get the new setup like Ernies.
The price on their website is $2000. Shop price is $1700.
Anthony
Old Nov 13, 2008 | 08:40 AM
Bacon's Avatar
IRS 4 Life
Anthony
Anthony,
After you snap one how extensively are you cleaning out the area in the diff? The both times I have first removed the broken outer axle, then used a strong magnet pickup tool to get out any chards, chunks of metal.(like 10 passes till it comes out clean 3-4 times Then taping the broken stub through from the other side. Another pass with the magnet from the other side Drain and fill the diff.
Are your tearing down the diff? just wondering if I’m short cutting anything
Old Nov 13, 2008 | 03:34 PM
AnthonyNYC's Avatar
Stay tuned...
Originally Posted by Bacon
Anthony,
I decided to pull the rear out, while it was out I checked everything inside and also replaced the bearings. put it back together. Now that I broke the area near the hub, I won't pull the rear again.
Anthony
Old Nov 13, 2008 | 06:03 PM
ErnieT's Avatar
Living life 9 seconds at a time
Mr. Bacon...
This is money well worth spent. I have been cutting low 1.4 60's with no ill effects. Actually when Anthony was helping me out Sunday I managed a 1.40 which is my best yet. I broke those things every damn week prior to the DSS upgrade. Then the output shaft every 3 passes, lol. Now thats all fixed too
Old Nov 13, 2008 | 06:30 PM
twokrx7's Avatar
Need more sleep
Great news Ernie, I'm glad I picked up this DSS upgrade. Although the DSS told me the stock ABS gears would fit the new halfshafts (outer cups) but they clearly will not fit. I plan to keep the ABS so I'll have some adaptors machined to mount the stock ABS gears onto the outer CV cups.
Old Nov 13, 2008 | 11:31 PM
ultimatejay's Avatar
The only real alternative you have to the Ernie axles would be to run a little higher pressure in the tires so they spin just a tad to take a load off the axles. The only thing with that is your 60ft times are not going to be as good. Like Ernie said, if you plan on racing alot, it's better to spend the money on the good axles because in the long run you end up spending just as much and have alot of headaches. I just laid down over 2500 bucks on a 9" for my rx2 when I paid 2000 dollars for the car, but I know I won't be breaking any rearend parts any time soon.
Old Nov 14, 2008 | 09:47 AM
Bacon's Avatar
IRS 4 Life
Originally Posted by ErnieT
Mr. Bacon...
I had a feeling you were going to say that. If I start saving now ill own them by the spring. LOL. Then the tail shafts will be my next i$$ue
I need to get my plumbers license and come work for you
congrats on the 1.40 thats awesome, glad you finally got the bugs out
Old Nov 14, 2008 | 01:46 PM
enzo250's Avatar
IRS Champion
Get the DSS axles.. I got them in my car, there slightly different then ernies since i'm using a different rear but nonetheless there the same otherwise..
Look at the expensive of going to track and always breaking your axles when you figure the price of the DSS and the amount of time/headaches saved..
Old Nov 14, 2008 | 02:31 PM
Bacon's Avatar
IRS 4 Life
nm
Old Nov 14, 2008 | 03:21 PM
Bacon's Avatar
IRS 4 Life
Old Nov 15, 2008 | 02:16 PM
justturbo2's Avatar
Registered User
Anthony did you every cryo treat the inner axle stubs.
if so how long did they last?
Old Nov 15, 2008 | 06:32 PM
AnthonyNYC's Avatar
Stay tuned...
I've never had them cryoed and they have lasted a few years without any issues. The first time I broke them I launched at a higher RPM than I normally do and the 2nd time (last week) was a mistake on my part.
We'll see what happens tomorrow.
Anthony
Old Nov 15, 2008 | 08:24 PM
Indian's Avatar
It wasn't me!!
What was the mistake Anthony? If you don't mine me asking...
Old Nov 16, 2008 | 03:21 AM
AnthonyNYC's Avatar
Stay tuned...
I think I left the nut for the axle loose... After it broke, the nut was completely loose, I doubt it can come loose from breaking...
I'm on they way to Etown now, I know they are both tight now
Anthony
Old Nov 17, 2008 | 07:21 AM
AnthonyNYC's Avatar
Stay tuned...
I went to the track yesterday and broke the part thats closer to the rear. Bad day to go to the track too, way too cold. Over the winter I'm going to upgrade to the new DSS axles. Good advice Enzo.
Anthony
Old Nov 17, 2008 | 10:46 AM
Bacon's Avatar
IRS 4 Life
from ray:
Len
Inner cv joint $230.18
Has to be ordered from Japan
Thanks
Ray
Now if we could just get someone to make the Main shaft in the Trans out of something stronger we would be in business
Old Nov 17, 2008 | 08:03 PM
twokrx7's Avatar
Need more sleep
DSS put the wrong outer cups on my kit, new halfshafts are on the way.
Old Nov 18, 2008 | 05:47 AM
crispeed's Avatar
'Tuna'
9 inch IRS conversion
That's very possible and have been done using 300m but it's still very limited to the stock dimensions which really is the problem. Even with the stronger shaft what's going to stop gear breakage in the tranny. You will be only moving up the chain to the next weak link and wasting $$$$ in the process like others have done before. Just give in and do it right in the first place like some record holders have been doing as of late.
Nine inch Ford IRS conversion for a Supra.
Old Nov 18, 2008 | 08:55 AM
timemachines's Avatar
man this looks awful familiar
Old Nov 18, 2008 | 09:01 AM
crispeed's Avatar
'Tuna'
I have no clue what you're talking about!
BTW. MYOB!
Old Nov 18, 2008 | 09:37 AM
enzo250's Avatar
IRS Champion
Lol
Old Nov 18, 2008 | 09:52 AM
AnthonyNYC's Avatar
Stay tuned...
BTW. MYOB!
Yeah!!!
Old Nov 18, 2008 | 04:22 PM
kabooski's Avatar
Laying Down Rotary Law
wow Eh Is that supra axles or custom after market ford axles?
How hard would it be to fit aftermarket brakes with a kit like that onto a FC or FD
or can you machine the FC/FD hub to fit 31 spline ?
Eeek any chassis shops here in Florida can handle a job like that?
Dutchman has a 9" center housing/CV only kit.(no 3rd) Guess I could fab up the rest myself hmmmmmmmmmmmm
