What are some really good 2nd gen Rexy combos?
Old May 15, 2002 | 03:15 PM
Ls1_Camaro_Man's Avatar
What would a really good combo be for an 2nd gen? I'm doing some research for my friend he wants a 2nd gen rexy. So you guys want to tell me your setups? and what kind of times you guys pull. He's kind of looking for bang for the buck with a Turbo on top hehe. But i would like to know some N/A combos to thanks a lot
Old May 15, 2002 | 03:38 PM
dre_2ooo's Avatar
Soul Assasin has a good setup. I think he runs in the 10's
Old May 15, 2002 | 05:22 PM
gnx7's Avatar
if your friend is mechanically inclined check out http://www.v8rx7.com and look at the forums for some "spirited" 2nd gen RX-7's.
or directly to the forum:
http://www.torquecentral.com/vb225/f...?s=&forumid=11
Mid 10's for $5K? Yes it can and has been done.
LS1+ 2nd gen RX-7 (there are 3 in the works)
GNX7
Old May 15, 2002 | 07:41 PM
CanadianRX7's Avatar
http://velocity.isfaster.com/new/rides/soul/main.htm
13B twin-rotor, bridgeport, 3 pc 2mm apex seals (shotpeened), low compression rotors, FD3S intake and throttle body, 1000cc primary/secondary injectors, HPI 60pi stainless steel exhaust manifold, HKS TO4R turbine 1.15 a.r, Greddy Type R wastegate, ARC GTR 3 core intercooler, aluminum cross flow radiator, stainless steel 80pi exhaust that y's off into 2 60pi duals with 115pi HPI (N1) mufflers, Greddy Type R blow off valve, disabled power steering and a/c, stainless steel fuel line, stainless steel oil cooler line, dual in-tank GTR fuel pumps, Hurst roll control (line lock).
HKS fully sequential transmission, ORC twin plate clutch, ORC lightened flywheel, Kaaz lsd, stainless steel cluch line.
HKS FCon V, Greddy Profec A boost controller, HKS AIC, Blitz turbo timer, defi 60pi boost and egt gauges, 9mm plug wires, NGK 11 plugs, B&M volt ignition amp, Perma cool 16 in. electric fan.
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
Wolf_
Aug 11, 2015 04:23 PM
