Hoist points on an FC 13B
Old Nov 9, 2008 | 07:12 PM
ArtOfRuin's Avatar
RotorDork
MA Hoist points on an FC 13B
My 1987 RX-7 GXL's oil pan gasket has gone bad, and I will need to replace it at some point. The engine is the stock 13B N/A. I already have the part I need on order. I know that I will need to support the engine with an engine hoist in order to undo the engine mount bolts and get to the oil pan. I've never used an engine hoist before, so my questions are:
-Where should I put the chains on the engine so that it's supported correctly? Pictures will help.
-Besides the fan and the battery, will I need to disconnect anything else?
-Besides the oil, will I need to drain any other fluids from the engine?
Thanks in advance.
Old Nov 10, 2008 | 02:13 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
There will be two Eye Hoops on the intake, one passenger side back near firewall, second driver side front of intake it is a little lower on the motor.
You should be ok.
Ian_D
Oct 14, 2015 12:31 PM
The1Sun
Sep 15, 2015 04:45 PM
Ian_D
Sep 6, 2015 10:38 PM
