1993 j spec swap lean condition?
Old Oct 28, 2008 | 11:06 PM
civichch's Avatar
Hey I just got a 1993 rx7 that had a blown rear apex seal, so i swapped a j spec into it and just got it running. I swapped all wiring and intake manifold from the original, and replaced all vacuum lines and hoses and fuel filter. It idles perfect and revs nice and sounds good with no load on it. As soon as I took it for a drive it falls on its face and I heard some nasty pinging!?! Sounds like a fuel or ignition problem, but im a total rotary newb! I know pinging is bad news for these engines, does anyone have any ideas for me? (:
Old Oct 28, 2008 | 11:38 PM
Mahjik's Avatar
Mr. Links
Check for ECU codes:
http://www.fd3s.net/engine_codes.html
Also verify:
* you have the ignition harness hooked up properly (right connectors to the right coils)
* you have the CAS connectors on the proper sensors
Old Oct 30, 2008 | 03:58 AM
civichch's Avatar
Dude, thank you sooooooooooooo much! I went right for the coil pack connection and noticed it was routed a little weird? So I took off the tbody and moved them around and boom the car runs perfect now!!!! I owe you big time (:
Shawn
Old Oct 30, 2008 | 12:47 PM
Mahjik's Avatar
Mr. Links
No problem. Glad it was something simple to sort out. Enjoy the car!
Queppa
Nov 18, 2024 03:47 AM
sYnth.
Aug 19, 2015 06:27 PM
