420rwhp 13bppt at 7300rpm and 9psi of boost!!!!!!!!
Old Oct 27, 2008 | 04:49 PM
Chaotic_FC's Avatar
and apparently it makes that 9 psi by 3000 rpm, idles easily at 1000 rpm and is very streetable
DOES ANYBODY HAVE ANY INFO ON THIS ENGINE??!!?!?!?!
http://ausrotary.com/viewtopic.php?f...a&hilit=13bppt
Old Oct 27, 2008 | 05:04 PM
Juiceh's Avatar
Saiga-12 Power!
Something tells me that asking the guy who posted it on that forum would be the best way to get that info...
Old Oct 27, 2008 | 06:45 PM
RacerXtreme7's Avatar
NASA geek
NICE, didn't you read the thread link you posted?????
"Now, if anyone is interested in an engine like this:
(these arnt the specs of the engine above either)
13B PP block, Guru 2 peice crank, guru stud kit, NRS Apex seals, modified oil system, 20mm sump plate, intake system with sinlge 100mm throttle body on custom plenum, fuel rails, endelie mechanical fuel pump, injectors, fuel regs and all fuel lines plumbed up, should be good for 900HP
approx $22000NZ depending on exact specs "
Must be simular, or why would he post those??
I read GT42 also
~Mike...........
Old Oct 27, 2008 | 06:49 PM
mono4lamar's Avatar
In the burnout box...
Pretty clean looking. They're running a 42r so I guess it's possible. It would be strange only running 9psi on a big turbo. I'm also assuming it's a peripheral port so right there's a nice advantage...
Old Oct 27, 2008 | 07:52 PM
The Shaolin's Avatar
Canned. I got CORNED!
My pants just got really tight.
Old Oct 27, 2008 | 08:12 PM
twomucboost4u's Avatar
Always Under Construction
You found the thread and didint event ake the time to read it?
"13B PP block, Guru 2 peice crank, guru stud kit, NRS Apex seals, modified oil system, 20mm sump plate, intake system with sinlge 100mm throttle body on custom plenum, fuel rails, endelie mechanical fuel pump, injectors, fuel regs and all fuel lines plumbed up, should be good for 900HP"
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
