Sponsored by: CARiD
White Build Up
Old Oct 15, 2008 | 01:20 AM
badandyrx7's Avatar
White Build Up
ok to day i was taking a motor out and when i took the header off i found a lot of white build up on it. does anyone know whats the deal with this? should i be worried about the life of the motor?
Old Oct 15, 2008 | 06:04 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
It is nothing really, just deposits from the extreme heat and the cast iron sleeves, they should be about the same. The front rotor looks like it has a injector leaking or lower than the rear compression. It is just different, but anyways everything is fine with that pic
Old Oct 15, 2008 | 11:29 AM
badandyrx7's Avatar
Cool Thanks
toplessFC3Sman
Mar 20, 2018 01:54 PM
