Microtech tune above 10psi
Old Oct 11, 2008 | 08:43 PM
Spannersrx7's Avatar
tune above 10psi
Ok so you guys have been a huge help so far so i thought i would try again..
My turbo has been played with a ruined.. (to4 front cover without changing wheels or anything) so it doesnt hold boost at rpm well at all so currently it will hit 9 psi and come down to around 7 but i would rather 12-13 psi and come down to 7 a it pulls alot harder.
So 2 plans of attack.. would upgrading wheels in stock s5 turbo work or better off with standard front cover on turbo would be happy with over 10psi at redline. not using standard wastegate got 44mm Tial.
Problem:
Tuner didnt tune above 10 psi so above that it leans out... which is stupid because boost cut is 16psi so if something failed and freeboosted it would lean out. so need to know how to adjust map for that boost
Engine is extend port. 500hp Bosch pump 550/660 injectors, full 3inch exhaust etc.
Old Oct 11, 2008 | 10:32 PM
rx72c's Avatar
Top Answer: 1
Show us your map. Will richen it up. easy.
Old Oct 11, 2008 | 10:38 PM
which map?
Old Oct 12, 2008 | 03:53 PM
rx72c's Avatar
Top Answer: 1
Load map.
Old Oct 21, 2008 | 10:50 PM
haha seems obvious now in first map..goes flat
Old Oct 21, 2008 | 10:52 PM
i mean second lol
Old Oct 22, 2008 | 07:02 AM
rx72c's Avatar
Top Answer: 1
Load map is fine. Timing map is fine. And so is your idle map.
Old Oct 22, 2008 | 11:18 PM
well how come it leans out as soon as i go above 10psi, it never used to
Old Oct 23, 2008 | 07:26 AM
BluRR's Avatar
you can try pulling up the 14psi value up some more and try it again...just keep pulling up the values until you stop leaning out. If you find you have maxed it out and you still going lean..then you have a fuel delivery problem..your pump isnt flowing enough
Old Oct 23, 2008 | 04:08 PM
rx72c's Avatar
Top Answer: 1
Richen up the 14psi map.
And see if it helps.
If it dosnt get any richer, then either your injectors or your fuel pump are maxed out or possibly both.
Old Oct 23, 2008 | 04:26 PM
BluRR's Avatar
Dude stop repeating me...they say impersonation is greatest form of flattery... but thats just ridiculous
Old Oct 23, 2008 | 04:58 PM
rx72c's Avatar
Top Answer: 1
lol **** didnt even realise.
hahahaha
Old Oct 24, 2008 | 01:08 AM
on the load map?
Old Oct 24, 2008 | 01:53 AM
rx72c's Avatar
Top Answer: 1
Yes the load map.
Old Oct 29, 2008 | 03:51 AM
ok changed the map and no more lean out actually goes rich as so have heaps of fuel so will take a little out.. gonna keep a/f round 11? and sometimes it stutters a bit but that may be the voltage? alt belt pretty loose havent tightned up yet a was only on 12.5 volts.. but a couple runs up to 6.5k rpm and went smooth as just real rich
Old Oct 29, 2008 | 09:00 PM
BluRR's Avatar
yeah...if its rich pull out some..you can aim for 11.5 AFR when you on boost
Old Oct 30, 2008 | 12:26 AM
alrite will give that a go tonight
Old Oct 30, 2008 | 03:03 AM
ok is there anything wrong with having it run a bit rich apart from not as much power?? and it has a misfire at around 3500 rpm in 3rd in 4th under full load
Old Oct 30, 2008 | 05:35 AM
rx72c's Avatar
Top Answer: 1
what does the missfire show up as on the afr meter.
nothing wrong with rich. how rich is it though?
Old Oct 30, 2008 | 11:22 PM
misfire jumps to lean a couple times then comes right.. could be something to do with sencondary injecters.. the correct phrase i cant think of now
Old Oct 31, 2008 | 12:32 AM
rx72c's Avatar
Top Answer: 1
at what load point is it doing it at?
what are you staging settings?
show us your staging settings.
Old Dec 9, 2008 | 02:15 AM
how do i find my staging settings
Old Dec 9, 2008 | 06:25 AM
rx72c's Avatar
Top Answer: 1
go the option menu
look opt_revstg
opt_mapstg
and opt stg%
Old Dec 15, 2008 | 02:57 AM
will get those values in a sec.. also i have an air leak and its really annoying.. can i pump more fuel in for starting etc. as it will run nice when warm just have to have the idle up but won't run at all cold because its going too lean
Old Dec 15, 2008 | 06:34 PM
rx72c's Avatar
Top Answer: 1
Water map . thats were you compensate for it when its cold. add fuel in that map.
