What does this thingy do?
Old May 13, 2002 | 08:01 AM
Samps's Avatar
Sorry no pic; but I can explain it! You know that one hose that comes off of the black intake tube that runs to that little electronic solenoid valve? Yeah; the one that runs into the dynamic chamber via a 60 degree hose. The hose goes right next to the VDI actuator. I'm assuming at some RPM it lets air into the dynamic chamber. I'm curious if this is necessary? If it is necessary, does it need to be metered air? Or can I just put one of those little air filters on it?
Old May 13, 2002 | 08:08 AM
Liquid Anarchy's Avatar
We come with the Hardcore
I tore my engine apart a while ago, and saw that. Mine's capped off w/ a factory looking cap. I assumed it was the vacuum feed to the cruise control.
Old May 13, 2002 | 08:46 AM
Samps's Avatar
You know what you are probably right. I have seen others with it capped off. My car used to have cruise but it doesn't work anymore. If that is, what it is, then I will deffinitely just plug it up.
Thanks!
Kruel13
Aug 26, 2015 12:17 PM
lerch32
Jun 27, 2002 03:59 PM
elizer
May 5, 2002 05:39 PM
DJChunter
May 1, 2002 03:40 PM
DCmina
Feb 19, 2002 08:57 AM
