Serious defrosting issues!
Old May 13, 2002 | 12:23 AM
JumpyRoo's Avatar
Okay, so I took the FC out to see my girlfriend for the first time since we bought the car--she's waited eight months to see it! So we say goodbye and I am heading out to Chicago while she heads off to work, and after watching her go down the road through my driver's window, I look forward and I *can't see anything*. We had some major major storms this morning when I left but seriously, this was ridiculous. I fiddled with as many different flow and temprature settings as I could, and after everything, I could only get a quarter of the driver's windshield defrosted. This really sucked for a 100 mile drive in the rain! Anyone fixed this problem yet?
Old May 13, 2002 | 12:32 AM
Icemark's Avatar
is air coming out of the defroster vents on the top of the dash when you have the logicon climate control in either the foot or defrost?
Is the outside air on?
You know having the air condition switched on (with the temp set to warm) also helps?
Old May 13, 2002 | 12:33 AM
JumpyRoo's Avatar
You bet it is.
Old May 13, 2002 | 12:35 AM
Felix Wankel's Avatar
Super Newbie
Does it blow strongly? My brother's car had a messed up Logicon that wouldn't let the fan blow at full speed. It sucked at defrosting too.
Icemark's Avatar
sorry I edited for more questions after you replied:
Old May 13, 2002 | 12:37 AM
JumpyRoo's Avatar
Yeah. The Logicon seems to be controlling everything just right. The flow is strong, and nothign goes where it shouldn't when the buttons tell something to go one place and not another. The airconditioner was taken out... I dunno if what you're saying would work now or not.
Old May 13, 2002 | 12:38 AM
Super Newbie
Windshiled ever been replaced?
Old May 13, 2002 | 12:39 AM
JumpyRoo's Avatar
Same, stock windshield. It's also very dirty. I saw these traces on it when it was heavily fogged, as if there were some residue. I've tried just about everything to clean the windshield since I got it, but I hadn't put it together that whatever is *on* the window could cause a bigger problem
Old May 13, 2002 | 12:41 AM
Icemark's Avatar
Well for best defrosting you would want air conditioning on, but since you don't have air you just lost 50% efficency.
I might double check the air mix motor and make sure it is going all the way over.
Old May 13, 2002 | 12:44 AM
JumpyRoo's Avatar
Hmm. Yeah, I didn't have much control over the air conditioner business. It sucks (it's hot here), I know.
I'll check the motor.
Any suggestions that wouldn't have to do with the exact functionality of the unit? Like... sprays, long term fixes. Modifications?
Old May 13, 2002 | 12:45 AM
Super Newbie
If it is leaking slightly it will be a pain to defrost. I found this out with my old Ford truck.
Old May 13, 2002 | 12:46 AM
JumpyRoo's Avatar
It seems, that for all my success with this car, I will ultimately be held up by defrosting issues
Old May 13, 2002 | 12:54 AM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
DEFROSTING?!?!?!?
is it that cold up there?? it has been between 80 and 90 for 2 months here
Justin
Old May 13, 2002 | 12:56 AM
JumpyRoo's Avatar
It'll be thirty one day and ninety another day. But yes, it's a problem. Eventually, it got on the driver's and passenger's windows, too
Old May 13, 2002 | 12:58 AM
JumpyRoo's Avatar
Oh yeah, and you know that defrosting wires that ascend the windshield? I didn't see any defrosting patterns going on there, whereas I did in the back hatch with those wires.
Old May 13, 2002 | 01:14 AM
fastrotaries's Avatar
W. TX chirpin Monkey
i don't think those are defrosting wires. I think they are the AM antennas. Some correct me if i'm wrong.
Old May 13, 2002 | 01:18 AM
Super Newbie
Yeah they are just secondary antennas. Look on some 70s and 80s GM cars and you will see the same thing.
Old May 13, 2002 | 01:26 AM
Sounds to me like the problem I had in my 280Z. My window seemed to have a film on the inside of the window and for the life of me I could not get it to defog. I found out that it was a bad heater core that was mixing anti-freeze and water into the heat blowing from my window defoggers. This stuff wouldn't just defog nor could you just wipe it off. What I ended up doing was replacing the heater Core and the A/C. Fixed the problem Could be whats happening to you. If you need to get it off the windows I recommend something that cuts through the Glycol. Try maybe windex/glass plus and some paper towels.
Old May 13, 2002 | 08:35 AM
JumpyRoo's Avatar
Man! I was hoping it wasn't a antifreeze leak but I had heard that before, oh man, ergh. Heater cores aren't cheap, are they? Erf
Old May 13, 2002 | 08:39 AM
Super Newbie
Nor easy to replace.
Old May 13, 2002 | 10:09 AM
JumpyRoo's Avatar
How can I test to see if there's antifreeze on the windshield? It doesn't smell like antifreeze...
Old May 13, 2002 | 11:09 AM
Josepi's Avatar
Despise Enmity
Fog-X on the inside, Rain-X on the outside .
Old May 13, 2002 | 11:12 AM
hehehe I'll vouch for this one, took me like 2 weeks of "sorta" working on it to finish. I had to take half my dash apart....blech
Well if theres a greasy (dunno if thats the right word for it) substance on the window, then I'd bet it's a heater core leak. Your problem sounds exactly like mine was when I described it to people.
Old May 13, 2002 | 11:14 AM
Super Newbie
Try it on a second generation F-body. Have to pull the passenger fender, inner fender, and dashboard. Sucks ***.
Old May 13, 2002 | 11:16 AM
ouch, that sucks!
P.S. My car just arrived today!!! It's IN CALI! I'm workin on arrangements to pick it up as we speak!
