Where to plumb an oil accumulator?
Old Oct 6, 2008 | 09:58 PM
Kill No Cone's Avatar
I would like to mount an oil accumulator on my current project. Where would/do you plumb the oil line to the engine?
I have used the search
Thanks for your time
Old Oct 7, 2008 | 08:39 AM
SCCAITS's Avatar
SCCAEP
My Accusump is plumbed into the oil cooler return line with a one way valve. You don't want the oil to have run back into the cooler, it should go straight into the motor.
Old Oct 7, 2008 | 10:31 PM
SCCA, that is great and make sense. What kind of valve did you use and where did you get it from?
Thanks ~ JEB
Old Oct 8, 2008 | 08:58 AM
SCCAITS's Avatar
SCCAEP
My setup is done with a 3/4" brass check valve to keep the oil from going back into the cooler. On/Off is controlled manually by a brass ball valve. It's all plumbed in -10AN. You can get the valves from most industrial plumbing supply places. Here is what the check valve looks like http://www.deanbennett.com/brass-check-valves.htm
Old Oct 8, 2008 | 11:04 PM
Thank you for the data and the photos. I assume that you have had no problems with the heat of the oil and the delrin seals in the valve? I chucked, I just changed the foot valve in my well system and have a spare one around!
Did you use the 125 psi or 400 psi valve?
Old Oct 9, 2008 | 08:47 AM
SCCAITS's Avatar
SCCAEP
Not sure which check valve I have. I got the check valve and Accusump from another racer and had the Accusump rebuilt. The ball valve and fittings I bought new. I have had no problems with my valve. I would go with a higher than 125 PSI valve for a race motor and make sure its rated high enough for the oil temps.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
