Go Back   RX7Club.com > Tech and Performance > Single Turbo RX-7's
Old 09-26-08, 07:31 AM   #1
spinnin3rd
missing my fd
rx6 vs. gt35r
hey guys im in the market for a single kit and im stuck between the 2 turbos stated above. im not shooting for high hp set up. 380-430 would be perfect. fast spool but i dont want it to choke up top, which is my concern with the rx6 so owners please chime in. thanks guys!
spinnin3rd is online now   Reply With Quote
Old 09-26-08, 08:43 AM   #2
spinnin3rd
missing my fd
also the car is primarily street driven and will only see a track once to see what times it can run.
Old 09-26-08, 09:04 AM   #3
Azcamel
Put it in her butt
Azcamel's Avatar
I only know about the GT series, i run a GT42 and a local guy runs A GT35R, he makes 400 on a mustang dyno and 440 on a dynojet at 14-15psi, he has a big port on his engine. I think he said he gets full boost in the 3400 range, but that is partly due to the port.
The ex car was a 94FD3S GT4202, Gotham Racing Monster Port, Zoom-Zoom
I Broke It so went to the other side, 2JZ Piston power!
Azcamel is offline   Reply With Quote
Old 09-26-08, 09:11 AM   #4
spinnin3rd
missing my fd
thats exactly where i want to be powerwise. now im just not sure how the two compare with spool. ive heard people say they cant tell the difference in spooltime between the rx6 and stock twins which is the huge turn on for me about that turbo. i loved my twins but hated dealing with them.
Old 09-26-08, 12:25 PM   #5
fd0
formerly chillin_rx7_guy
fd0's Avatar
One other thing to consider when considering which route to go is how much is it going to cost to rebuild the turbo when it comes time for it.
Currently the Garrett turbos are popular so you should be able to have available parts for the forseeable(sp?) future. The Apex'i, as far as I know, can't be rebuilt and the purchase price of the turbo(if you can find it) is over $3,000.
Hopefully you'll never have to rebuild but there's a good chance you will in the future.
Good luck.
to FD or FC.... that is the question
fd0 is offline   Reply With Quote
Old 09-26-08, 12:36 PM   #6
R.P.M.
Huh.....how bout that!
R.P.M.'s Avatar
We built an FD with a special streetport which helps bottem end spool and power with an RX6 on it. It works very nice, comes on hard around 3000rpm. We are only running it at 12-14 psi and it roughly makes 400whp. It pulls right to 8000rpm
So many Mazda's its not even funny...
R.P.M. is offline   Reply With Quote
Old 09-26-08, 12:59 PM   #7
spinnin3rd
missing my fd
yes thats another thing ive been weary about. the rx6 turbo alone is 2,000 from rx7store. i plan on buy a lightly used turbo so finding the right rx6 is going to be tough. what does the upper rpms feel like with the rx6, R.P.M ?
Old 09-26-08, 08:14 PM   #8
R.P.M.
R.P.M.'s Avatar
Pretty decent, I dont like holding it wide open too long because of the LOUD external wastegate lol. But I'd say it doesn't run out of steam up top.
I didn't realize the turbo cost that much. The 35R is much cheaper.
Old 09-26-08, 08:20 PM   #9
spinnin3rd
missing my fd
thanks for the info.
any more with the rx6 ?
Old 09-27-08, 05:57 PM   #10
spinnin3rd
missing my fd
anything else ?
Old 09-30-08, 04:19 AM   #11
SpiritR_21
New Member
Does Apexi still make the RX6 kit?
SpiritR_21 is offline   Reply With Quote
Old 09-30-08, 01:57 PM   #12
TrentO
TrentO's Avatar
My GT35R on a Turbo II makes about 400 rwhp at 15psi
My friend's Apexi RX6 makes about 350 rwhp at the same boost. He comes in earlier than I do, but up high I make a lot more power. The hotside on the RX-6 is pretty small and starts to choke out the rotary up high. He got a deal on the Apexi kit and I bought the A-spec kit so we spent about the same money and the GT35R seems to have higher horsepower potential.
my $0.02
-Trent
TrentO is offline   Reply With Quote
Old 09-30-08, 01:59 PM   #13
RotaryRocket23
Oh yeah, the GT35R definately has a lot higher potential.
I would say the powerband on the RX6 travels from 2500-6500 and the powerband on the GT35R, depending on setup, ranges from 3500-7500
RotaryRocket23 is offline   Reply With Quote
Old 10-01-08, 06:00 PM   #14
eirerx7
New Member
gt35r spools alot quicker, great for street
eirerx7 is offline   Reply With Quote
Old 10-02-08, 12:15 AM   #15
RotaryRocket23
Definately doesn't spool faster than a RX6, but it definately carries the power up top where the RX6 will kinda fall on its face.
Really depends what the overall goals are. You will be able to make your horsepower range on the RX6 with higher boost levels (17-18~ psi) while you will be able to make that kind of power at only 10-14~ psi on the GT35R
Old 11-10-09, 07:08 AM   #16
beqa16v
beqa16v's Avatar
Send a message via ICQ to beqa16v
can anybody second that? I mean does it make as much power as stock at 2500?
1995 JDM FD Type R
HKS Dual Intake
High Flow CAT
5Zigen Exhaust
beqa16v is offline   Reply With Quote
Old 11-10-09, 02:17 PM   #17
quattro4now
Rotorite
quattro4now's Avatar
For the money and power goal, a T04E with a 57 or 60 trim would likely be a better pick than the GT35r. If setup properly it should spool a little quicker than the GT35r and produce the same power as the RX6 at lower boost levels similar to the GT35r.
quattro4now is offline   Reply With Quote
Old 11-10-09, 07:18 PM   #18
HalifaxFD
Soon to be single
HalifaxFD's Avatar
I just ordered a GT3574R from A-spec. Sean told me it makes more power at lower boost levels than a 35r and it a great track street setup. You should hit Sean at A-spec for some clarification and comparisons.
HalifaxFD is offline   Reply With Quote
Old 11-10-09, 08:28 PM   #19
WaachBack
Finally Knows
WaachBack's Avatar
Trader Score: (12)
Send a message via AIM to WaachBack
An RX6 is way to small if you ask me. Get a GT35R or GT35/74.
1993 R1, Ported, built and tuned by me.
Old Setup: Non-Seq stock twins @ 18psi on 92 Pump with 315cc W/I. - 11.4@117 Mph.
New Setup: GT35/74@24psi single turbo on 92 Pump with 550cc W/I - xx@xxx Mph.
WaachBack is offline   Reply With Quote
Old 11-24-09, 09:36 AM   #20
CrispyRX7
Polishing Fiend
CrispyRX7's Avatar
Trader Score: (21)
Facts only and not hearsay:
http://www.reganrotaryracing.com/fde...doverview4.htm
Dyno plots at the page bottom.
GT35R on a mild street port. Short run manifold.
10psi at a little below 3600rpm
422rwhp at 15psi
FWIW,
Crispy
CrispyRX7 is offline   Reply With Quote
Old 11-24-09, 10:56 AM   #21
howard coleman
Send a message via AIM to howard coleman
"Facts only and not hearsay:"
RX6
cold side aver area 6.356 sq inches
hot side 4.315
GT35r
cold 6.386
hot 5.171
GT3574 (A-Spec)
cold 6.386
hot 5.89
the rotary likes lots of hotside. big hotside =s less EGT and less EMP=s less talking to engine builders.
hc
howard coleman is offline   Reply With Quote
Old 11-24-09, 11:12 AM   #22
black06g85
that random guy
black06g85's Avatar
I personally prefer the gt35r
I run a gt3582r on my car 1.06 T4 divided housing 3" v-band outlet.
Thing spools almost instantly on the street and it put down 383.2whp on 12.xx psi on 93 octane with a street ported motor.
response is awesome on shifts and from rolls.
2006 cobalt ss/sc turbo swap 500+whp (until motor blew lol)
9500 rpm pull (2nd one)
93 RX-7 383WHP 12psi pump gas
black06g85 is offline   Reply With Quote
Old 11-24-09, 10:10 PM   #23
CrispyRX7
Polishing Fiend
CrispyRX7's Avatar
Trader Score: (21)
Outstanding Howard.
Crispy
Old 11-24-09, 11:20 PM   #24
1Revvin7
The answer is simple
1Revvin7's Avatar
Trader Score: (7)
Send a message via AIM to 1Revvin7
Ditto. I will never use one again...
1Revvin7 is offline   Reply With Quote
gt35, gt35r, gt42, hot, mazda, powerband, rx6, rx7, sale
Will Apexi Rx6 Downpipe Match GT35R? Z_rx8 Single Turbo RX-7's 2 03-24-08 10:55 AM
what rx6 is this? facapino Single Turbo RX-7's 1 01-07-08 12:46 AM
T-78 or RX6 GUESS? Single Turbo RX-7's 39 12-06-02 09:59 PM
m2 vs. rx6 yodaddy 3rd Generation Specific (1993-2002) 3 11-18-02 12:10 AM
Rx6 Phase 2 Single Turbo RX-7's 4 03-16-02 03:00 PM
