Need help with Soul's mtr
Old May 11, 2002 | 11:23 PM
tofstr32gtr's Avatar
Soul's car blew another apex seal on the dyno today. Last time the rear seal let go at 1.4 boost. Rebuilt mtr into full bridge and added msd 6a's because it looked like detenation caused the first seal to go. Today on the dyno at 1.3 the front seal let go. The a/f stayed around 11.5 and there was no spikes in the duty cycle of injectors,egt nothing. It let go at about 6300rpm. Can't find anything obvious and don't want to put another mtr in as it will probably do the same. He is suppossed to put the car in the box on wed. to ship to states. I have never messed with rotaries but could the coils be weak? By the way it picked 53hp from partial to full. Up from 381rwhp to 434rwhp at .8 boost
Old May 12, 2002 | 12:14 AM
Node's Avatar
poor soul, and good luck with the tuning.
Old May 12, 2002 | 12:46 AM
Scott 89t2's Avatar
SOLD THE RX-7!
how many Kms on the motor before you dyno'd ??? was it even broken in?
Old May 12, 2002 | 01:35 AM
It had 800km on it. All at no boost and 5000rpm max.
she is now coming back with a t51 kai ballbearing!
to4r for sale!
Old May 12, 2002 | 01:49 AM
What happened to Soul's tuner, I thought he was going to get that engine covered under warranty. I remember soul defending bridge porting for the street and he said it was all about tuning. Which I do believe that you can run a properly tuned bridgeport on the streets. But why is he having so many problems. I know everyone one the board thinks the best tuners are in Japan. Why is he having so many problems getting his car running properly??
Old May 12, 2002 | 02:07 AM
BoostedRotors's Avatar
I HATE sleepy eyes
I thought his car put down in excess of 500 hp?
Old May 12, 2002 | 02:23 AM
Felix Wankel's Avatar
Super Newbie
Yeah but .8 bar is only about 11 psi, his turbo was hardly breathing at that boost level
Old May 12, 2002 | 03:04 AM
gorockrx's Avatar
Arrow Bummer
Sounds like the timing is off with the new setup, cause the rest sounds ok. I'm no expert, but with good EGT, A/F, and no spikes, sounds like too advanced on the trailing or maybe some cross firing with the new ignition setup.
Not a weak coil, but maybe a connection on one of the MSD's? Sounds like trailing timing or cross firing on the trailing ignition to me. I have been doing some studying of this since I blew my motor.
Just an idea anyway. Does he have a stand-alone or what? Maybe a J&S Knock Sensor setup would help?
Old May 12, 2002 | 03:59 AM
RETed's Avatar
Stock Mazda apex seals?
-Ted
Old May 12, 2002 | 04:11 AM
Liquid Anarchy's Avatar
We come with the Hardcore
with THAT kind of power/money, I'd be running Atkins 2pc. at least, if not 1pc.
Old May 12, 2002 | 04:26 AM
jspecracer7's Avatar
1JZ powered
I don't know about 1 piece...
Old May 12, 2002 | 07:37 AM
There is at least five other cars from that tuner with the same mtr combo not hurting parts. He has a HKS Fcon v pro. It did the same thing with the other ignition. Going to try putting fd coil packs on it.
Old May 12, 2002 | 08:25 AM
1JZ powered
-Ted
...Soul Assassin went full bridge. Wouldn't want the corner of the apex seal to fall into the intake runner would we
Old May 12, 2002 | 08:30 AM
87GTR's Avatar
can we see the dyno sheet? I want to see how a turbo bp starts building power and how the lower end torq is.
do anyone have is old dyno sheet for half BP
I would like to see it too.
Old May 12, 2002 | 08:34 AM
87GTR's Avatar
ok your say .8 bar 58hp diff was the .8 a full pull on the dyno?
how was the hp diff at 1.3bar when the apex seal broke?
Old May 12, 2002 | 12:47 PM
Tofstr32gtr, How much is Soul selling his To4R? is he selling the kit or just the Turbo? and what spec is it?
Chrisleegtt@hotmail.com
Old May 12, 2002 | 06:40 PM
Scott 89t2's Avatar
SOLD THE RX-7!
to4r for sale!
that's probably why right there... that's like 500 miles.. you should have put a few thousand K's on first. I don't think it was broken in enough.
Old May 12, 2002 | 10:13 PM
soul assassin's Avatar
GTR eater
well the motor was well broke in don't need thousands of miles on it since all we changed were the rotors and housings. the turbine only is going for 800 bucks here anyone like it drop me a email at dragfc3s@yahoo.com
they are stock apex seals but they are wpc'd (shotpeened)proven to hold up under 1.6 bar
we are pretty sure it is an ignition problem hte timing was also right on sdon't remebr how far advanced it was but it was well within limits. and it would only start sputtering under high boost at 6k low boost it was fine
also it was the front rotor that let loose so would the trailing crossfirng make a difference if that is the problem?
Old May 13, 2002 | 05:25 AM
RETed's Avatar
Power FC, right?
and it would only start sputtering under high boost at 6k low boost it was fine also it was the front rotor that let loose so would the trailing crossfirng make a difference if that is the problem?
Any chances you can get those dyno sheets scanned in?&nbsp I'd be very curious to see if there is anything obvious that can be picked out from the dyno runs...
-Ted
Old May 13, 2002 | 05:55 AM
GTR eater
fcon v pro ecu i can try for the dyno sheet no promises though
Old May 13, 2002 | 06:40 AM
RETed's Avatar
Yeah, I just read a response from you in the Single Turbo section.
Maybe I'll just wait till you move closer...
-Ted
Old May 13, 2002 | 05:13 PM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
well i guess it is good that you arent running it on larger seals, since these are blowing it is telling you that you have a problem, while larger seals might just hide it longer.
(a message from Captain Obvious)
Justin
Captain Hook
Sep 22, 2015 01:12 PM
chiefmg
Sep 10, 2015 07:46 AM
