13bt into s2 rx7
Old 09-24-08, 04:40 AM
pattie05's Avatar
13bt into s2 rx7
hey guys i was wondering how difficult it is to fit a s4 or s5 turbo motor into an s2. and does anyone have any idea on were to look for decent half cuts?
cheers patrick
Old 09-25-08, 05:22 AM
160.000km 10a
siks3's Avatar
hello there i am from tassi but i now live in sa.
regarding dropping in a 13bt into the series 2 i dont think it is legal the only first gen you can legaly put a 13b in is a series 3 and sourcing motors ect go see lawrie williams in devonport at rotech automotive he has built me a few exelent motors in the past he will get you on the right track my 13b bridge port he built me was ******* awsome
Old 09-25-08, 06:23 AM
pattie05's Avatar
thanks for the advice mate and yea we use lorry all the time. can u at least turbo a bridgeport motor in a s2
Old 09-25-08, 07:26 PM
160.000km 10a
siks3's Avatar
turbo 12a bridgeport kick *** really smooth power i was going to do that as well and use a series 5 turbo set up you can get a plate that makes the manifold bolt up but i decided against it and went and got a cosmo turbo front cut but yea the turbo bridge 12a is a good idea you will have to run a moderate boost level if you dont have lower compression 12a turbo rotors you are so lucky lawrie does exelent builds at the best prices i have seen he realy knows his **** and is a top bloke to boot he is there to build exellent motors for his customers with none of the hype and over priced bullshit some of the other shops use to fund there own projects good luck with the build with lawrie on your side its going to be a kickass motor with no head aches during the build and it will last a long time.ROTECH AUTOMOTIVE ALL THE WAY
Old 09-25-08, 07:35 PM
packin' heat
rotarymandan's Avatar
That was a long sentence. But you know what you're talking about!
Old 09-26-08, 06:31 AM
pattie05's Avatar
thanks alot for the advice im thinking of maybe going a 13b bridgie and just getting it mod plated but i would like to own a turbo. and as for lawrie he is a great bloke with great prices and motors
Old 09-26-08, 07:04 AM
160.000km 10a
siks3's Avatar
still check with the rta i think its a power to weight thing that makes it illegal if its a savana it will be ok but a normal series 2 is a no 13b zone there is a good thread on ausrotary about this i would check it out before going 13b or pick up a series 3 and get a lsd rear disk breaks standard
Old 09-28-08, 03:00 AM
pattie05's Avatar
alrite then mate thanks a heap for the advice
Old 09-28-08, 03:22 AM
SAE Junkie
Jobro's Avatar
theres no lsd in any australian delivered Gen 1 rx-7.
I also disagree somewhat about a 12at bridgeport being smooth power. I would suggest a 12at if you wanna go that way, but a 13b import block is the best option when you ignore legatity. The price of a refreshed 13bt import block is going to be the cheapest way of making the car reliably fast.
Old 09-28-08, 08:19 PM
pattie05's Avatar
yea im gonna look into putting a series 4 motor into it but thats a while away need to make things strong enough to handle one first
82streetracer
Haltech Forum
11
03-11-19 05:34 PM
Th0m4s
02-26-19 02:04 AM
Quick Reply: 13bt into s2 rx7
