Microtech Base map for MTX-8 (sequential fire)
Old Sep 22, 2008 | 08:11 PM
Lynch's Avatar
Lynch
Does anyone have a base map for a MTX series ECU (NOT LT series).
Injectors are 2x600cc & 2x1680cc.
Thanks
Old Sep 23, 2008 | 01:37 AM
rx72c's Avatar
Top Answer: 1
it makes no difference mate.
this should get you close
Idle Map
Screen 1
30" ~ 1.38
25" ~ 1.48
20" ~ 1.43
15" ~ 1.81
10" ~ 1.83
05" ~ 2.05
00" ~ 2.40
2-20psi ~ 4.95
Load Map
Screen 3
30" ~ 0.95
25" ~ 1.19
20" ~ 1.33
15" ~ 1.71
10" ~ 2.14
05" ~ 2.57
00" ~ 2.86
2psi ~ 2.2
4psi ~ 3.05
6psi ~ 3.7
8psi ~ 4.1
10psi ~ 4.7
14psi ~ 5.2
16psi ~ 5.6
18psi ~ 5.8
20psi ~ 6.2
RPMwot Map Screen 17
5000 ~ 05
5500 ~ 08
6000 ~ 08
6500 ~ 10
7000 ~ 11
7500 ~ 11
8000 ~ 11
9000 ~ 12
The rest are zero
RPMcrs Screen 18
1000 ~ -12
1500 ~ -11
2000 ~ -12
THe rest are zero
Pump Map
Screen 19
Pump2Start ~ 2000
Pump1Amt ~ 00
Pump1Pulse ~ 04
Pump1Trig ~ 18
Pump1Stop ~ 00
Pump1Adv ~ 05
Pump2Time ~ 10
Pump2Amt ~ 30
Pump2Trig ~ 16
Pump2Stop ~ 00
Pump2Adv ~ 05
PumpDwell ~ 3.00
PumpTimers ~ No
Pump1Sync ~ No
PumpSpare ~ 00
PumpCold ~ 00
Water Map
Screen 20
-25 ~ 0
-17 ~ 70
-9 ~ 60
-01 ~ 50
05 ~ 45
11 ~ 45
18 ~ 42
24 ~ 34
31 ~ 26
38 ~ 24
46 ~ 19
60 ~ 12
68 ~ 06
82 ~ 0
99 ~ 0
124 ~ 0
Air_t Map
Screen 21
-25 ~ 0
-17 ~ 8
-9 ~ 6
-1 ~ 5
5 ~ 4
11 ~ 3
18 ~ 3
24 ~ 0
31 ~ 0
38 ~ 0
46 ~ 0
60 ~ 0
68 ~ 0
82 ~ 0
99 ~ 0
124 ~ 0
Crank Map
Screen 22
-25 ~ 72
-17 ~ 72
-9 ~ 72
-1 ~ 67
5 ~ 62
11 ~ 57
18 ~ 50
24 ~ 41
31 ~ 31
38 ~ 26
46 ~ 20
60 ~ 15
68 ~ 5
82 ~ 0
99 ~ 0
124 ~ 0
t*rpm
Screen 23
Idle ~ 20
1000 ~ 20
1500 ~ 20
2000 ~ 20
2500 ~ 25
3000 ~ 25
3500 ~ 25
4000 ~ 25
4500 ~ 25
5000 ~ 25
5500 ~ 25
6000 ~ 25
6500 ~ 25
7000 ~ 25
7500 ~ ??
8000 ~ 25
9000 ~ 25
t*map Map
Screen 24
Idle ~ 00
25 ~ 05
20 ~ 04
15 ~ 03
10 ~ 02
05 ~ 00
00 ~ 00
2psi ~ 00
4psi ~ 00
6psi ~ 02
8psi ~ -04
10psi ~ -06
14psi ~ -10
16psi ~ -12
18 psi ~ -16
20 psi ~ -20
t*air Screen 25
Correction value Is expressed as number of degrees you wish to advance or Retard to the Ignition curve and values Is set at zero.
t*gap
Screen 26
0500 ~ 15
1000 ~ 15
1500 ~ 15
2000 ~ 14
2500 ~ 12
3000 ~ 10
3500 ~ 10
4000 ~ 10
4500 ~ 10
5000 ~ 10
5500 ~ 10
6000 ~ 10
6500 ~ 10
7000 ~ 10
8000 ~ 10
t*Inj Map
Screen 27
0500 ~ 120
1000 ~ 150
1500 ~ 150
2000 ~ 150
2500 ~ 150
3000 ~ 150
3500 ~ 150
4000 ~ 150
4500 ~ 180
5000 ~ 210
5500 ~ 210
6000 ~ 240
6500 ~ 240
7000 ~ 270
8000 ~ 270
9000 ~ 270
t*wat Map Screen 28
ANd the rest are zero
Option Map
Screen 30
Af_StE ~ 10
Dwell ~ 3.25 *set at Time Base - not at Duty Cycle*
REVstg ~ 1320
MAPstg ~ 02"
%stg ~ 50
Old Sep 23, 2008 | 03:28 PM
Lynch's Avatar
Lynch
Screens are different. Not the same as MT series. For example screens are F1, F2, F3, S1, S2, S3, etc. I play around with it again today & figure it out.
Old Sep 23, 2008 | 04:49 PM
rx72c's Avatar
Top Answer: 1
dosn matter what screens. use the data above and put it in your computer.
if you havnt figured that much you dont know how to use the handset.
Old Sep 24, 2008 | 07:40 PM
Lynch's Avatar
Lynch
Figured it out & it runs good. Thanks. Hoping to get it tuned this weekend!
Old Sep 24, 2008 | 10:53 PM
rx72c's Avatar
Top Answer: 1
So the map worked?
24seven_dada
20
Nov 10, 2018 12:03 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
windom
Sep 11, 2015 04:48 AM
