Rotary Drag Racing The place to post your racing stories and info
Started on my 4 Link Today..........
Old Sep 16, 2008 | 02:37 PM
Viking War Hammer's Avatar
*** Bless The USA
Smile Started on my 4 Link Today..........
chassisworks battlecruiser kit, got it measure/cocked and tacked today...... gotta run it tommorow morning to be tigged
from 4 link bracket to 4 link bracket, i have 25 inches with 1.5 inch of clearance between the bracket and the frame rails
streetcar
Old Sep 16, 2008 | 03:03 PM
*** Bless The USA
oops
Old Sep 16, 2008 | 03:15 PM
*** Bless The USA
coilover setup
Old Sep 16, 2008 | 03:28 PM
RoTaRyBoYz's Avatar
InsaneRotaries.com
Looks good...
is that a explorer housing?? My mustang 8.8 has 2 stupid " rabbit ears" on the top, it took me forever to cut them out..
Old Sep 16, 2008 | 04:02 PM
*** Bless The USA
It's out of a 90 5.0. Yeah, I cut those bastards off. Cutting all those brackets off are a pain in my ***.
Old Sep 17, 2008 | 02:57 PM
gusfd3s's Avatar
E85 Addict
looking fun
I started a 4link project on my rx3 a couple of years ago but never completed it, it was supposed to become a street/drag car but now it is only collecting dust.
maybe i should've let a pro do the chassie setup.. it's never to late i guess
Good luck man!
Old Sep 17, 2008 | 03:20 PM
Doc Holiday's Avatar
Needs more cow bell
viking, that **** looks pretty good.
Old Sep 17, 2008 | 03:31 PM
*** Bless The USA
Originally Posted by gusfd3s
looking fun
Good luck man!
Cool Project!!
You got anymore pictures? Like one from the back looking into the trunk at the crossmember?
Old Sep 17, 2008 | 03:32 PM
*** Bless The USA
trying to decide what type of locator to use? panhard bar or a diagnal bar? what do you guys think?
Old Sep 17, 2008 | 07:30 PM
Busted7's Avatar
Will work for horsepower
Looking good Eric i went with diagnal bar!
Old Sep 17, 2008 | 08:03 PM
Needs more cow bell
Diagonal bar for sure. The panhard lets the rear end walk sideways in the chassis as the chassis seperates. I just get weirded out by that. Besides, you *should* have more room under there by using a diag vs a panhard. Just my meager opinion.
Old Sep 17, 2008 | 08:07 PM
*** Bless The USA
thanks doc,
do you guys have a good way at determining how high my crossmember needs to be mounted in the car? Like, it needs to be 12 inches off the ground, and so and so?
I know my bottom 4 link bar needs to be parallel...... sooooooo
I want my car to sit low, so I need to make sure my crossmember is at the right spot and make sure the crontrol arms are at the right angle.......
Old Sep 17, 2008 | 08:08 PM
Needs more cow bell
Originally Posted by Viking War Hammer
Cool Project!!
Is this what you are wanting?
Old Sep 17, 2008 | 08:09 PM
*** Bless The USA
See my previous question SHOWOFF!!! haha, nice dude!
Old Sep 17, 2008 | 08:14 PM
13B-RX3's Avatar
7s before paint!!!
If you plan on driving the car on the street a lot i would use a wishbone.
Old Sep 17, 2008 | 08:15 PM
Needs more cow bell
thanks doc,
well..... my chassis guy welded my crossmember directly tot he two side rocker panels. When I think back on it, It seems like they are always mounted this way. Ive never seen em mounted higher than that. The rear frame rails can be taller or shorter, and then you mount the front bar brackets to that. The higher up you mount em, the lower the car will sit. See what Im sayin? Thats JUST MY OBSERVATION. I am by no means a chassis guy.
Old Sep 17, 2008 | 08:17 PM
Needs more cow bell
here is a pic to reference what I was just posting about......
Old Sep 17, 2008 | 08:24 PM
*** Bless The USA
Right, I was told that chassis shops always weld them to the rockers because rockers never change height on all cars. Not sure how true that is.
I was also told that I could weld it directly beween the frame rails.
Take a look at these 1st gen RX7 pictures. Let me know what you think since they were done completely different.
One had a square crossmember like mine, and he welding his on top of the frame rails. The other is using a roung crossmember. They are both using the trall brackets, mine are the shorter ones. Just trying to get a idea if mine should be mounted on top of the frame rails are between.
Old Sep 17, 2008 | 08:32 PM
Needs more cow bell
well, the first thing I think of is, with the factory frame rails intact, it limits how low the car will sit. Like, on that second pic, half of that upper bracket looks wasted, cuz they wont be able to get the car low enough to ever use it, cuz the frame rails are in the way. I would think you would just cut that **** out and make your own frame rails. I guess you would keep it if you wanted your **** to either A) look more stockish, or B) were required by a certain class to have certain frame rails intact or some ****. My rear end sits INSIDE the damn car, there is NO WAY I could have the car as low as I do if the rear floor were still at its origional height.
Allen should be chiming in! That bastard works at a damn chassis shop! Why is he holding out on us!?!?!?!
Old Sep 17, 2008 | 08:36 PM
*** Bless The USA
Yeah, that's alot of adjustment on the top side of that bracket but like you said. Not usable. I don't want to cut out my frame, I'm hoping to run "stock style" suspension class we have locally. I figure if I can get the crossmember in the general area, I got a bunch of holes in the brackets to make adjustments right? haha
Allen works at a chassis shop? What the heck, why's he holding out?
Old Sep 17, 2008 | 08:48 PM
13B-RX3's Avatar
7s before paint!!!
What are you asking? I don't feel like a lot of reading so give me the cliff notes.
Old Sep 17, 2008 | 08:51 PM
*** Bless The USA
You lazy ***.......... read!
Crossmember height/location. This is what I need to know. Mount between frame rails or on top of frame rails? Or to the rear bumper?
Let me know chassis guru.
Old Sep 17, 2008 | 08:53 PM
13B-RX3's Avatar
7s before paint!!!
Buy my BOV and i will tell you.
Old Sep 17, 2008 | 08:55 PM
*** Bless The USA
I would, but that's dead weight fool!
Old Sep 17, 2008 | 08:57 PM
13B-RX3's Avatar
7s before paint!!!
It's light.
Don't worry about the frame rails. Make it so that the bottom of the crossmember is flush with the bottom of the rocker (not the pinch weld) and then you can figure how to tie in the frame rails. Make sure to "plate" the area where the crosmember welds to the rocker also.
