1 pice apex seal vs 2piece(ceramic)
Old Sep 15, 2008 | 06:02 PM
siks3's Avatar
160.000km 10a
hi
im about to stard disasembling my 13b re engine from a cosmo to put in my first gen and i need a little bit of help.
im going to purchase a set of nrs ceramic seals and im a bit confused on what type to use 1 piece or 2piece?
(thinking 1 piece cause there cheaper)
im going to be running a turbo allso so in my mind 1 piece seem the go.
what do you guys think?
Old Sep 17, 2008 | 02:12 PM
86TII's Avatar
Both have pros and cons
pros
1 piece less moving parts
stonger
cons
harder to fit for install
as the plates wear the the apex seal doesn't
pros
2 piece as the plates wear the end of the apex moves to seal the space
easy to set the spacing
cons
more moving parts
when apex seals blow it normaly the small corner of a 2piece
Old Sep 17, 2008 | 11:18 PM
siks3's Avatar
160.000km 10a
pros
stonger
cons
pros
cons
more moving parts
Im realy starting to lean towards the 1 peice seal.
im running a 10a in my rx3 that has 160.000k on the clock and when i recently tore it down to replace the oil control rings everything else was in spec still.
that engine has 1 piece seals so they are capable of lasting.
the 10a still has exelent compresion as well even after so many kms.
Snook
Oct 8, 2015 10:09 PM
