HELP!! Rx7 that wont pass emssions test
Old Sep 15, 2008 | 07:42 AM
Chillski's Avatar
Exclamation HELP!! Rx7 that wont pass emssions test
hey guys, i got a huge problem i bought a 91 rx7 as of last week. it has a racing beat dual exhaust with no cat and it wont pass inspection here in ny. everybody i talked to said it wouldnt be a problem cause the car is obd1 and they'll only do a visual but apparently this isnt the case.
so now im bein told that i need to buy a dual catalyic converter and that its gonna run me about 1000 bucks to get done in the garage. ive spent a lot of time looking but i cant seem to find a dual high flow cat to put on this exhaust.
if someone can tell me where to find one, or what i should do PLEASE HELP!! my car is parked out on the street ive already gotten one ticket for no inspection, i cant afford to keep this up.
Old Sep 17, 2008 | 04:40 PM
2gentim's Avatar
laf@crustangs
id say screw new cats. ive got friends in cal who need to pass emisions as well but they say if u ask around u can usually find someone who will just pass your car as is. i dont know if thats the case in ny but if it is then screw cats.
Old Sep 17, 2008 | 11:04 PM
Jpk3200's Avatar
Jpk3200
What are you failing on?
Originally Posted by FAQ
Old Sep 17, 2008 | 11:18 PM
southsidecox's Avatar
tigers LOVE pepper!!!!!
Talking all good ideas
there are also fuel additives that help alot one i use is lucas fuel systym conditioner(urine colored) makes my exhaust go from obnoxious to way less obnoxious
Old Sep 18, 2008 | 12:17 AM
misterstyx69's Avatar
Retired Moderator, RIP
search Bonez Hi flo cat on google(or here). and you need a cat to pass an emissions test.How else is the car gonna get the Bad particles out of the Exhaust?,Pure magic?..and the Racing beat system will allow that cat to be installed.Make sure that nothing else has been removed from the Engine.The air pump is also vital to the car's operation of the emission's system...New member for sure.The best advice I am going to Pass your way is go through the Archives(sec gen) and READ..if it has been done,altered,fixed,broke and Removed and replaced,the Forum's Sec gen archives and Gen Specific Sections are there.The info is there for the Taking.,It contains "Shiiyte" that guys have compiled over the years so,put your reading glasses on and fill up your coffee mug and go at it!..I wish you luck.Peace.STYX.
Old Sep 18, 2008 | 12:30 AM
Icemark's Avatar
Gonna be tough to pass without at least one cat. The unburnt HC is gonna be really high
Old Sep 18, 2008 | 03:23 PM
stylEmon's Avatar
FC since 99
why would you need two cats on a rotary? Single side exhaust that splits into two right...?
Just replace the mid pipe with a cat.
Old Sep 18, 2008 | 03:51 PM
2Lucky2tha7's Avatar
Back at it again!!
and if you're still not passing, run a 50/50 ratio of denatured alcohol and gasoline in your fuel tank. I personally ran mine down to 2 gallons left and then added 2 gallons of denatured alcohol. The mechanic was really puzzled when he saw how low my readings were
Old Sep 18, 2008 | 04:31 PM
Chillski's Avatar
hmm thanks for all the info everybody... im defintely gonna keep researching the topic but i see monkeymagic is selling a high flo bonez cat in the for sale section. does anybody kno if this would work on my racing beat exhaust?? would it need to be welded in? how much would u guesstimate it'd cost?
and btw i needed this 3rd post to pm him
Old Sep 18, 2008 | 05:11 PM
look up the exhaust..and see if it will fit.I am fairly certain it will.and if it doesn't see if the installer can put flanges on it.that way you just make another test pipe.Put the Pipe on once the car Passes Etest..Oh here. http://www.rx7.com/store/rx7/fcexhaust.html
Old Sep 20, 2008 | 02:14 AM
WHTEVO's Avatar
Damn that sucks. I'd try to find someone who you can pay to pass it. I've had to do that more than once so good luck.
Old Sep 20, 2008 | 07:20 PM
Ukrarex's Avatar
+1 U deffenetly need ur air pump, with out it u have no air pumping trough the exhoust to speed up the chemical reactions in the cat. Does mixing alcohol and gas really work sound dengerous
Old Sep 21, 2008 | 03:45 AM
Chillski's Avatar
thanks for all the advice, i found a friend of mine who said he can pass it... it'll be about 3 1/2 hour drive but that should be problem solved!!
Old Sep 21, 2008 | 09:06 AM
stylEmon's Avatar
FC since 99
really works, not dangerous.
Old Sep 21, 2008 | 06:43 PM
wakazz's Avatar
Bay Area Rotary
yep
yea i screwed in new cats for mine to pass smog
Old Sep 21, 2008 | 08:56 PM
Ukrarex's Avatar
cool thx, im going to try it out in next mount, when my inspection is out
Old Sep 21, 2008 | 09:33 PM
kejames's Avatar
OR He doesn't pass because required equipment is not there.
Some of theses guys are on the right track. you need to go to another DMV facility and see if you can go through it. You just got unlucky and they were being sticky that day. Good luck and try again.
KJ
Old Sep 21, 2008 | 10:32 PM
Beartoothrun's Avatar
Rookie rx-7er
move to montana or wyoming, no emissions what so ever, problem solved
Th0m4s
Feb 26, 2019 02:04 AM
efini7
Test Area 51
Sep 4, 2015 02:59 AM
