Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
ITB options
Old Sep 5, 2008 | 01:30 PM
user 8202's Avatar
Question ITB options
Hello.... im an rpm kinda guy with the love of that godamn ear peircing high rpm rotaries give..
who offers bolt on itb set ups out there
engine 6 port s4/s5
Old Sep 5, 2008 | 03:33 PM
rglbegl's Avatar
B A N N E D
tweak it makes one - http://www.tweakit.net/shop/index.ph...521da3961ea534
I have also heard of people using the Suzuki ITB's as well.
What are the goals of the car?
Old Sep 5, 2008 | 03:37 PM
blackedoutFC3S's Avatar
HKS obsessed
http://www.fuji-racing.com/fujiracing_009.htm
http://www.tweakit.net/shop/product_...roducts_id=117
and yes tweak it and i think theres one more
Old Sep 5, 2008 | 04:10 PM
RacerJason's Avatar
Coming to a track near u!
If you search ITB within this forum you'll find a couple threads with some good ideas and information. A few of us are using Hayabusa throttle bodies as ITB's others are using more sophisticated setups. It al starts with $$ and ends with a lot of tuning!
Old Sep 5, 2008 | 04:25 PM
user 8202's Avatar
Thanks guys!.. so tweak sells them for about seven hundred and some change.. not bad at all..
The plans for the ride
micro tech for the brains, i have the full racing beat exhaust, with the lightened fly wheel and a 6 puck.. im ready for some High reving FAST RESPONSIVE N/A power.. i dont care too much about high output, im more concerned about response.
im not porting anything.. just polishing..
those are the plans... its funnest to me ..... just like the 4ag guys
Old Sep 5, 2008 | 04:28 PM
HKS obsessed
some guy on here is running busa ITB's, just type in ITB's in the search and you'll find some nice info man
Old Sep 5, 2008 | 04:39 PM
rglbegl's Avatar
B A N N E D
786.36 Australian dollars = $635.850696 U.S. dollars
And if you are a 4AG guy . . . . you rock!!!! AW11 FTW!!!!
Old Sep 8, 2008 | 01:15 AM
sen2two's Avatar
Rx2 > FD
i got gsxr 600 ITB's for $30 on ebay. and i made my ITB manifold for almost free. got some metal for free, some for cheap.
but the fuel system and tuning might be costly...
Old Sep 8, 2008 | 02:18 AM
HKS obsessed
we need pics and some type of write up for this
Old Sep 8, 2008 | 10:02 AM
RacerJason's Avatar
Try these:
Interesting reading for those who haven't taken the plunge:
The costs: https://www.rx7club.com/canadian-forum-42/real-costs-my-itb-set-up-661987/
This and that: https://www.rx7club.com/canadian-forum-42/itbs-ftw-648413/
600 cycle ITB's are likely choking your motor. You need something more free breathing hence 1200 or 1300 throttles.
Old Sep 8, 2008 | 02:53 PM
sen2two's Avatar
Rx2 > FD
each TB is 40mm. thats 40mm per port! so thats 160mm TB! picture that in a single form. the 1200-1300cc motor ones ar 44mm i think. not much of a difference. but big enough to have tuning problems and lose power.
stock 2nd gen TB's are around 60mm? i dont know. but even boosted race cars dont have that much CFM flowing to the motor. (in most cases)
aftermarket ITBs dont get any bigger than two 58mm for rx7s. and most use a 51mm with huge bridges or PP. were almost doubling that using bike ITB's. its not the best route at all. but, wayyyy cheaper. if your going to use bike ITB's. go for the smaller ones.
Old Sep 8, 2008 | 03:21 PM
Kenku's Avatar
spoon!
Uhm... no. 40mm diameter per port works out to two 56mm throttles or so in terms of area, or one 80mm one. Except you can't directly compare it to one 80mm one because both rotors aren't drawing maximum flow at the same time; ITBs need more flow potential than a plenum setup as the variation on flow through the throttles is a lot larger than if all rotors or cylinders or whatever are drawing through one throttle even if the average works out.
That and some of the aftermarket IDA style throttle bodies get up to 62mm per rotor.
Old Sep 8, 2008 | 03:23 PM
RacerJason's Avatar
I am surprised that the 600's are that big, Busa's are just a fraction bigger at 42mm if I remember correctly.
Old Sep 8, 2008 | 03:48 PM
sen2two's Avatar
Rx2 > FD
my measurements are at the throttle butterfly. not the opening or closing. most bike ITB's (if not all) are tapered.
kenku, im wondering how you got your math done? not saying your wrong. but i dont see it? good point on stating that the rotor is pulling less air due to being split with no plenum. but still, 40mm per port is pleny large. and still a little exsessive...
Old Sep 8, 2008 | 07:21 PM
Kenku's Avatar
spoon!
First off, for the equivalencies, area. Two 40mm butterflies don't have the same area as an 80mm one. 40mm butterfly has 1256mm^2 of area (ignoring the shaft) while an 80mm one has 5026mm^2 of area. Going back and solving for the same area of 2 40mm butterflies ends up with one with about 56mm.
Old Sep 8, 2008 | 08:07 PM
-xlr8planet-'s Avatar
I has an emblem
I have a set of CBR600RR itbs
I selected them for the following reasons
a) Im just running a half bridge
b) its a 12a
c) wont go higher than 8000rpm
d) 8 nice 190lbs injectors, nice atomization
e) wax rod for cold idle
f) tps (and it was free)
g) vacumm in each tb
h) 40mm
and the best:
25 bucks plus shipping!
Old Sep 8, 2008 | 09:30 PM
rglbegl's Avatar
B A N N E D
My math teacher always said we would need to know this stuff
Funny part is; I learned that one when figuring out pizza prices. Broke bachelors get very creative for food.
Old Sep 8, 2008 | 10:06 PM
dj55b's Avatar
https://www.rx7club.com/showthread.p...ht=fuji+racing
Old Sep 9, 2008 | 12:09 AM
EpitrochoidalPower!'s Avatar
Well seeing as dj55b set the trend
https://www.rx7club.com/naturally-aspirated-performance-forum-220/my-bridgeport-project-754841/
Old Sep 9, 2008 | 09:30 AM
dj55b's Avatar
i'm just searching for them saves me from retyping everything
Old Sep 9, 2008 | 11:39 AM
peejay's Avatar
Old [Sch|F]ool
It gets worse than that when you figure airflow and not just area. Surface area adds friction to the airstream, so two 40mm tubes will not flow as well as one 56mm hole all other things equal.
Old Sep 9, 2008 | 04:12 PM
Kenku's Avatar
spoon!
Oh sure, definitely. And more of the open area's taken up by throttle shaft and butterfly edge with more smaller TBs of theoretically identical area too as well... I wasn't intending to do anything more than a lazyman's approximation.
Old Sep 9, 2008 | 05:25 PM
sen2two's Avatar
Rx2 > FD
thanks kenku. for clearing it up...i must go back to math class
xlrbplanet, what injectors are you using? from a stock car or aftermarket? are you using the stock rails? got pics of your set-up?
i been wondering wich route to go with injectors. i was thinking four 550's. im running it on a un-ported renesis.
Old Sep 9, 2008 | 10:23 PM
I has an emblem
I will use the 8 injectors that came with the ITBs, they are DENSO injectors. Same for the fuel rails
Old Sep 24, 2008 | 08:10 PM
TehMonkay's Avatar
Back in the game
Isn't the p-port setup carb from racing beat 51mm, so then 4 40mm throttle bodies would be more than that then, correct?
renjiv2
57
Jan 25, 2024 03:34 AM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
manoflego
19
Sep 30, 2015 05:19 AM
