Haltech Stock ECU with Haltech 3 BAR Sensor
Old May 9, 2002 | 08:14 PM
raven bc's Avatar
Apex seal blower
Ok I've got a Haltech E6K with the Wiring harness from K2RD. I hooked everything up but my MAP needs tweaking. So I decided to plug back the stock ECU for the time being. The only problem is I've installed the 3 BAR Haltech sensor. Will this work with the stock ECU? I've tryied starting the car with it and it won't start. It starts to hook at 500RPM then just dies. Any help would be appreciated, thanks.
Raven
Old May 9, 2002 | 08:18 PM
raven bc's Avatar
Apex seal blower
Never mind I've been informed that it won't work, Damn I was hoping to avoid putting the stock sensor back in.
Raven
Old May 10, 2002 | 04:54 AM
RETed's Avatar
The stock FD MAP sensor runs up to about 17psi at full +5.0VDC.&nbsp The Haltech 3-bar MAP runs up to ~29psi at full +5.0VDC.&nbsp Isn't it obvious?
-Ted
