Timing/Pinging issue
Old Sep 2, 2008 | 09:49 AM
runsanrx's Avatar
I have an '84 GSL-SE. Just put a used engine in it with unknown past. Compression with regular compression gauge minus the schrader valve appears to be ~95 at each peak and fairly even between housings.
When starting it seems to fire against the starter nearly stalling the starter a few times but it does start and run. Driving it seems OK other than pinging on high load w/low RPM (lugging). You don't have to try to make it happen.
I set the timing with a light but it still seems to fire against the starter. I verified TDC with a Dial indicator in the leading hole against the rotor just to make sure the pulley marks were correct.
I disconnected the leading and trailing advances and plugged them. Still rough start and pings.
Ideas?
I'm going to recheck the compression again since it has run a little.
Last edited by mar3; Sep 2, 2008 at 02:35 PM. Reason: Deletd state icon...save those for private classified ads, thx
Old Sep 3, 2008 | 11:52 AM
runsanrx's Avatar
MN
I have not checked compression but I did disconnect the trailing coil secondary wire and the hard start and ping is gone.
I tried to disconnect the primary lead wire(so the coil wouldn't arc somewhere) expecting it to run without a tach reading but it did not fire???
I tried another distributor (spares are great) but same issue
Any suggestions now???
Coil, ignitor (doubtful since second dist had same result), other?
Any ideas appreciated...
Old Sep 4, 2008 | 01:01 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Bad Cap?
Bad Rotor?
Plug Wires Crossed?
Also Welcome to the Club
I am Chuck, Helper of ALL
Old Sep 6, 2008 | 08:40 AM
runsanrx's Avatar
MN
[QUOTE=Rx7_Nut13B;8522165]Bad Cap?
Bad Rotor?
Plug Wires Crossed?
Chuck, thanks for welcome and the feedback. I just swapped cap, rotor, and wires from my race car.
It still fires against the starter and pings under load.
I'll check the compression as I was going to do before.
If that still looks good I think I'll remove the UIM and check for leaks?
rgordon1979
40
Mar 15, 2022 12:04 PM
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
betes
Sep 27, 2015 08:25 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
