Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
idle problems on bridgeport
Old Aug 30, 2008 | 06:39 PM
lonewolfrx's Avatar
the car fires right up now but will idle at 3k rpms then die down and stall. I adjusted the cam idle screw, check fuel pressure, afm. need some advice. thanks
Old Aug 31, 2008 | 04:56 PM
socalrotor's Avatar
My car did the same thing when the afm took a crap. I know ya checked it, but that was my experience. It was a s4 btw.
Old Sep 1, 2008 | 12:35 PM
mannyvidal's Avatar
come get some.....
possible intake leak
Old Sep 1, 2008 | 01:45 PM
lonewolfrx's Avatar
i see.. ill try and check the car today.. ill try my spare afm as well.
thanks for the input..
Old Sep 1, 2008 | 05:39 PM
lonewolfrx's Avatar
ok i checked the intake .. put new gaskets on them. changed my afm.. still same problem.
it will stay runnin if i hold the gas a bit..
Old Sep 1, 2008 | 06:14 PM
mannyvidal's Avatar
come get some.....
wheres your idle at ? if you dont have any intake leaks or timming issues you should be ok , bump the idle up some and advance the timming ....
Old Sep 1, 2008 | 06:47 PM
lonewolfrx's Avatar
its goes to 1500 but then just drops down and stalls
Old Sep 25, 2008 | 11:57 PM
CobraS89's Avatar
GXL
it could be a bad throttle position sensor i had the same problem and today i just fixed it. have yours tested at the gas station they will tell you how much power should be running through it when your ignition is turned on. let me know what happens if this ended up solving your problem
Old Sep 26, 2008 | 10:10 PM
lonewolfrx's Avatar
hmm ill check it soon. its been raining so i have had no chance to go out and check it.
Old Sep 27, 2008 | 01:25 AM
fidelity101's Avatar
Rallye RX7
sounds like it could be a vacuum leak, if you light a cigarette and put it near all the intake gaskets, with a little RPM, you can see the intake draw smoke from the cigarette.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
rx7shirley
Sep 2, 2015 02:11 PM
