18x9+32 18x10+32
Old Aug 28, 2008 | 08:49 PM
kaisernaut's Avatar
18x9+32 18x10+32
Would this sizes and offset fit a FD?
Old Aug 28, 2008 | 10:01 PM
dclin's Avatar
Perpetual Project
Yes, if you're going for the stretched tire/drift look. If you planning a traditional fit with wider tires, no.
Old Aug 28, 2008 | 10:12 PM
Mar48's Avatar
from i've seen you want to be mid 40's or higher with that setup
Old Aug 29, 2008 | 01:51 AM
DK's Avatar
DK
40k worth of fail
Old Aug 29, 2008 | 10:28 AM
purerx7's Avatar
Registered User
You might be able to fit a wider tire on a rolled fender, not much though - dclin is spot on.
Old Aug 29, 2008 | 02:26 PM
BC-FD3S's Avatar
what about a 18x10 +38 all around? I know they will fit, but with a roll, what kind of tire sizes would I be looking at?
I want these http://phase2motorsports.stores.yaho...9in18x100.html
and they only come in +38.
Old Sep 2, 2008 | 10:08 PM
PBFRFF282's Avatar
^^^^^^^^^^ 245/40/18 for the stretched look or 275/40/18 for an aggressive stance look. 245 stretched might clear with just rolling inner lip in fender wells, i happen to like the stretched look. GL
Old Sep 2, 2008 | 10:19 PM
Jaiyurai's Avatar
Endure Persevere Succeed
won't clear front or rear unless you run wide fenders or do the stretched tire and some camber.
My setup with Enkei NT03+Ms:
FRONT - 18x9.5 +27 with FEED front fenders. 265/35/R18 tires
REAR - 18x10.5 +30 with RE-Amemiya rear fenders. 295/30/R18 tires
Old Sep 3, 2008 | 08:11 PM
ls1swap's Avatar
Veteran: Air Force
nope
