popping coilovers
Old Aug 25, 2008 | 04:59 AM
0verb00st's Avatar
popping coilovers
My coilovers pop when im driving at a low speed (parking lots) while turning. What causes this and how do I stop it. I heard I have to take an impact wrench and tighten the top nut. It sounds like only the front right coilover is making the noise.
Old Aug 25, 2008 | 05:06 AM
DK's Avatar
DK
40k worth of fail
Yeah try tightening first... they may just be loose. Since you have Max coilovers, the pillow ball could also have an abnormal amount of play in it, causing the noise.
Old Aug 25, 2008 | 05:49 AM
0verb00st's Avatar
Originally Posted by DK
The pillow ball could also have an abnormal amount of play in it, causing the noise.
How could I check this. Does this have an adverse effect on handling?
Old Aug 25, 2008 | 04:15 PM
0verb00st's Avatar
I tightened everything down. How much pressure should be on the springs? Shouldnt it be snug but not tight to prevent preloading? I tightened everything down and it is still popping (didnt use the impact wrench...)
Old Aug 25, 2008 | 04:25 PM
theflatlander's Avatar
Dual Wielding DieGrinders
your pillowball mounts are binding. you need new ones. If you leave it as it is you'll wear out the piston in the shock as its rotating instead of the pillowball.
Old Aug 27, 2008 | 12:29 PM
RE TurboII's Avatar
Meow
Call Dan at the shop and tell him your situation
Old Sep 1, 2008 | 05:37 PM
teknolust72's Avatar
Spring binding?? did you set the preload correctly on the springs?
Old Sep 1, 2008 | 06:17 PM
mannyvidal's Avatar
come get some.....
Originally Posted by teknolust72
Spring binding??
+1 wrap some wire on the botom of the springs so they dont slip old scca trick with popping springs
ls1swap
Jun 3, 2024 03:25 PM
renjiv2
57
Jan 25, 2024 03:34 AM
