Microtech Coil wiring question
Old Aug 20, 2008 | 11:50 PM
ctguy's Avatar
This seems like a odd question, but I am wiring up my coils. I bought a used lt-8 system and I am trying to wire the coils. Trailing no problem. The leading is a single coil system, in the wiring diagram it says a power+ and a L1 and a L2. Do I just jump these together or what?
Thanks for the help
Old Aug 21, 2008 | 03:51 AM
rx72c's Avatar
Top Answer: 1
What coil packs are you using?
You MUST AND I REPEAT MUST use factory s4/5 coil packs and ignitors.
Old Aug 21, 2008 | 10:11 AM
ctguy's Avatar
I am using the Factory coils, but for now I have them wired up without the ignitors. I guess I need to wire in the ignitors, but am not sure how they wire up.
Old Aug 21, 2008 | 03:12 PM
rx72c's Avatar
Top Answer: 1
easy to wire up.
LEADING COIL PACKS
TAN 12V IGNITION
PINK GREY/BLUE MICROTECH
TRAILING COIL PACKS
TAN 12V IGNITION
TAN 12V IGNITION
PINK GREY/RED MICROTECH
WHITE GREY/BLACK MICROTECH
YELLOW TACHO OUTPUT
GREY WIRE leave it disconnected.
Thats how you wire up the ignitors.
DONE.
Old Aug 25, 2008 | 05:40 PM
asiandude15's Avatar
Serious rx72c u should make a sticky, the thread that I had a while back with u telling me exactly how to wire up the LT8S was practically a sticky....
Old Aug 25, 2008 | 06:39 PM
rx72c's Avatar
Top Answer: 1
hahhaha. i dont have time to make a big thread, usually only on the computer for 10-15 minutes max at a time.
plus everytime i answer a question keeps it fresh in my mind.
Old Aug 26, 2008 | 07:14 PM
ctguy's Avatar
Thank you guys. I got it all wired and she started up last night first time. I was kinda supprised.
Thanks again
Old Sep 9, 2008 | 06:54 AM
lousrx2's Avatar
Anyone using MSD boxes with microtech
Old Sep 10, 2008 | 11:38 PM
rx72c's Avatar
Top Answer: 1
I try to stay clear of msd. JUNK.
Old Sep 12, 2008 | 09:05 AM
lousrx2's Avatar
Msd
Can anyone verify this. If I have my distributor at -5 degrees. And my static timming on my microtech at +5 degrees. Does that put me at 0 degress prior to starting the car? Also my Ignition timming at idle is +10 on the microtech ignition map. When I unlock my timming map on the microtech and I put a timming light on my pulley should I be at +5 degrees?
Old Sep 13, 2008 | 08:52 AM
rx72c's Avatar
Top Answer: 1
Get rid of the static timing. Make that 0.
Then with the +10 at idle you will have at +5.
Old Sep 13, 2008 | 07:56 PM
lousrx2's Avatar
Timming
Thanks
The Shaolin
Sep 14, 2015 07:50 PM
MoTeC
Sep 10, 2015 07:58 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
