You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join RX7Club.com today!
what did you guys set your map to for these monsters. When I hit about 3-4 psi and 3500 rpms it is like slamming into a brick wall. I've logged the event and it happens right as the secondary flag goes to true. my setup is below
use the 550/720 preset.. and i believe i had another 25% taken out at 6+psi, above staging rpm. this is with 750 primaries, and it would still stumble sometimes in 1st gear, but higher gears would run alright
yeah whatever your correction was at 6psi and above, take out at least 25%. Also above your staging RPM. If your staging is 3500 rpm, then only take out 25% above that, and 6psi and above. below 3500 rpm at any boost would stay the same
