Old 08-09-08, 02:25 AM   #1
ITSWILL
Wiring Nightmare
ITSWILL's Avatar
Injector size recomendation
heres my specs
streetport
walbro 255
3in exhaust and downpipe
rtek7 2.1 +(safc if needed)
bnr stage 4 turbo 15 to 18 psi
Should I run 550 or 720 primaries
As for secondaries 1600s ???
Im shooting for 400 whp
Also will I need a new fuel rail and FPR?
Money = Power
Rotaries are like a bad relationship, they piss you off so much you don't want anything to do with them, then they run so good you would never want to do without them.
ITSWILL is offline   Reply With Quote
Old 08-09-08, 10:14 AM   #2
gxl90rx7
breaking stuff
gxl90rx7's Avatar
Send a message via AIM to gxl90rx7 Send a message via Yahoo to gxl90rx7
720cc primaries, 1000cc secondaries minimum.. i tried 1600's but had trouble tuning the transition, maybe if you can find some 1200's or something
gxl90rx7 is offline   Reply With Quote
Old 08-09-08, 03:08 PM   #3
boost_its_what_for_dinner
RotoriousRx7
boost_its_what_for_dinner's Avatar
you wont need a safc since the rtek 2.1 requires a pda for the tuning device.
also i have hit the max of my 1000cc at 13 psi on 35r so id go 1200cc;s min.
fpr... rising rate aeromotive is what i have, i have stock rails but will be getting a new secondary rail when i upgrade to 1600's
87 T2 : RR rebuild/SP/JHB jugs : gt35r .82 t4 : 720/1600 : 3"full exhaust : Walboro 255 : big Fmic : KOYO rad./16"e-fan : Greddy Profec b : Apex i bov : uego wb02 : E6X : premix
boost_its_what_for_dinner is offline   Reply With Quote
Old 08-10-08, 10:25 PM   #4
ITSWILL
Wiring Nightmare
ITSWILL's Avatar
The idea for the safc was for additional tuning if i need more fuel correction. but thanks for the recommendation.
Money = Power
Old 08-11-08, 08:58 AM   #5
gxl90rx7
breaking stuff
gxl90rx7's Avatar
im still using the stock fuel rail and FPR with 1600's.. you just have to take a dremel to the top part to get them to fit. the stock fuel rail and FPR are fine, there is no way a walbro will outflow them
Old 08-12-08, 12:20 AM   #6
ITSWILL
Wiring Nightmare
ITSWILL's Avatar
Are these what I need?
http://www.rx7store.net/product_p/bosch%201600cc.htm
Money = Power
Old 08-13-08, 11:50 AM   #7
gxl90rx7
breaking stuff
gxl90rx7's Avatar
yep, but they are hard to tune. ever since the load-based staging "fix," rtek does not turn on the secondaries at a set boost level.. so its hard to figure out where to cut fuel in your maps. i would go with 1200's, they should be easier to tune
Old 08-14-08, 02:27 AM   #8
ITSWILL
Wiring Nightmare
ITSWILL's Avatar
I couldn't find 1200s, so I just went ahead and bought those 1600s. Hopefuly I can get them to work out. Do you have any recommendations for what brand and where to buy the 720s. I saw the greddy ones buy what hoping to find something for about $100 or less each.
Money = Power
Old 08-14-08, 08:59 AM   #9
gxl90rx7
breaking stuff
gxl90rx7's Avatar
Im using these:
http://www.rceng.com/Saturated-Injec...top-P64C6.aspx
high imp so you dont need resistors
Old 08-14-08, 05:02 PM   #10
ITSWILL
Wiring Nightmare
ITSWILL's Avatar
I just ordered up a set, thanks for the info.
Money = Power
Old 08-14-08, 07:52 PM   #11
fredox19
fredox19's Avatar
I don't think you would be able to go beyond 14psi, because of the AFM(which max out at 14psi). Currently you can't remove with the Rtek2.1
fredox19 is offline   Reply With Quote
Old 08-15-08, 01:30 AM   #12
turbo2ltr
You can, you just wont have any fuel/timing tunability above 15 psi...so its not really recommended..
turbo2ltr is offline   Reply With Quote
Old 08-16-08, 10:06 PM   #13
ITSWILL
Wiring Nightmare
ITSWILL's Avatar
could I run an SAFC on top of it for more fuel if I run more boost?
Money = Power
Old 08-17-08, 06:32 AM   #14
fredox19
fredox19's Avatar
So your telling me that I can go 16psi(of course not on the stock turbo) on the AFM if I get the Rtek 2.1 and just get it tune?
Injector size? blazer1313 2nd Generation Specific (1986-1992) 7 05-17-08 02:59 PM
??'s On Injector Size Flyinbiya 3rd Generation Specific (1993-2002) 31 03-27-03 10:23 AM
Injector size Vroomaster 2nd Generation Specific (1986-1992) 10 08-23-02 12:14 PM
Injector size Codey 2nd Generation Specific (1986-1992) 3 12-27-01 10:52 PM
injector size A-Spec 3rd Generation Specific (1993-2002) 1 10-02-01 04:13 AM
