How best to run my fuel system
Old Aug 7, 2008 | 06:45 PM
TURSTY's Avatar
The wankel way!!
Hi guys, I have had a look through a number of old posts around this but havn't found anything all that recent.
Currently I have a single FD with standard fuel rails and injectors and an Airtex intank Fuel pump running through the standard lines. Its al prety much stock apart from the breather line is not connected.
I have a KGParts secondary rail and 1680 injectors and plan to run the standard secondary 850s as the primaries in the standard primary rail.
Im now looking at getting all the lines and fitting together to install the new rail.
Im planing on using a second intank pump, using the standard feed and return as feed lines and the breather as the return as many have done and a FPR.
Is is best to run the two rails in series or paralell?
If I run them in series then I can just buy the banjo adapter from KGparts and the install will be easy. Running them in parallel will be a little harder but not a problem really.
What is the best way to go?
Old Aug 7, 2008 | 07:22 PM
Busted7's Avatar
Will work for horsepower
I dont think theres enought difference to really matter!
Old Aug 7, 2008 | 09:27 PM
TURSTY's Avatar
The wankel way!!
Is there any preference as to what rail to run first in the serries?
Old Aug 10, 2008 | 06:20 PM
TURSTY's Avatar
The wankel way!!
Also I have just brougt a second fuel pump and want to know the best way to utilize the factory hard lines to the firewall.
Was thinking of the following:
Is this the best way to utilize these?
Old Aug 10, 2008 | 08:22 PM
Busted7's Avatar
Thats what i have except i ran one pump per fuel rail and tied them at the fpr.
Dont forget fuel filter. I removed the pump assembley and drilled a hole for the return line and brazied it from the inside were its very clean[no gas fumes].
3/8s break line works good for return.
Old Aug 10, 2008 | 11:24 PM
TURSTY's Avatar
The wankel way!!
So something like this would work well? or would you run both returns to the FPR instead of the T piece? Will this still keep presures in both rails even?
Do you have the factory primary rail?
Old Aug 11, 2008 | 12:03 AM
Busted7's Avatar
Thats pretty much how mine is run but the fuel pressure regulator has two in's and one return on it.
I have aftermarket rails on both with top feed inj. 500 h/p for over ayear no problems. 850's-1680"s inj. holdes steady pressure with a base of 42 psi.
Good luck.
Old Aug 11, 2008 | 12:22 AM
sk8world's Avatar
Chasing numbers
on this topic whats a good size filter to run inline? I have ben running 2 small edlebrock,s but worried they may be to small. What is the rating I should be looking for?
Old Aug 11, 2008 | 06:44 PM
TURSTY's Avatar
The wankel way!!
Ill give this design a go. The reason Im a little concerned about the fuel presure is because the two fuel pumps are not the same. They will be the same rating but different brands because I cant get another one the same as what i have.
Old Aug 11, 2008 | 08:58 PM
TURSTY's Avatar
The wankel way!!
Also what are the primary rails made from? Cast alloy?
Old Aug 11, 2008 | 11:00 PM
Busted7's Avatar
I belive extruded alum 5051. Some are cast.
The difference in fuel pumps if there is any will balance volume and pressure at the regulator before returning pressure to the tank.
Old Aug 13, 2008 | 03:39 AM
TURSTY's Avatar
The wankel way!!
Thanks Busted, The last question I have is, is there any point running one way valves/check valves in the lines in case one pump fails, or is it not possible for fuel to flow that direction through a non running pump? The valves are expencive so Id rather not run them if theres no point but will if they will add safty to the system.
Old Aug 13, 2008 | 09:18 AM
Busted7's Avatar
Theres no need for check valves and if you did loose a pump it will still work all four injectors but the volume and pressure will drop. Thats why you need to moniture the afr's when your driving it hard!
You can install a hobbs safty pressure switch should you loose a pump and shut down the spark! I dont have one but it can cut ing. in an emergency.
Old Aug 13, 2008 | 09:34 PM
TURSTY's Avatar
The wankel way!!
Ok this is the design I have settled on for the Firewall foward:
Only issue I have now is where to put the fuel presure gauge. I have a malpassi fuel reg that only has two inlets and one outlet. I'll probably just buy a new one with a build in gauge.
Thanks for all the help Busted7. Ill post up what I do with the hardlines back to the fuel tank when I have measured it all up.
Old Aug 17, 2008 | 10:39 PM
TURSTY's Avatar
The wankel way!!
Repaired the link for the above photo:
Old Aug 17, 2008 | 11:14 PM
Busted7's Avatar
Nice drawing looks right to me!
Old Aug 18, 2008 | 12:47 AM
tony94s4's Avatar
Corn Fed FD
I have the same setup,
my stock fd pump feeds the stock prim,
hi press walbro feeds 1600 sec,
so if I eliminate the T and run both lines to
aeromotive fpr will that help the balance flow
or it will not make any difference?
thanx
tony
Old Aug 18, 2008 | 12:53 AM
tony94s4's Avatar
Corn Fed FD
Good luck.
Busted,
love ur setup,
do 850 prim efect the idle and drivability?
and if u dont mind me asking what kind of gas milage r u getting?
thanx
tony
Old Aug 18, 2008 | 08:57 AM
ChrisRX8PR's Avatar
I am working on a fuel system too and I left the breather/emissions tube operational(was kinda worried about it causing any problems with vapors in the tank), used the stock fuel line as return and will now route a separate 1/2" tube from the fuel pumps all the way forward to a Y that will then split into two 6an to each fuel rail. I will have one pump run at all times and one will come on with boost via a pressure switch and a relay. It will have 720cc primaries, 1000cc Primary2s and 1680cc Secondaries. The reason for running only one pump is that I am worried the return will not be enough to control pressure when at idle and the fact that having both pumps running all the time will just heat the fuel.
The 1/2" tube isn't that expensive and it might be a viable option for the OP as well in case you don't want to mess with the fuel vapors tube.
What do you guys think?
Chris
Old Aug 18, 2008 | 09:15 AM
Busted7's Avatar
Originally Posted by tony94s4
Busted,
love ur setup,
thanx
tony
Unless the T is restrictive i dont see why it would work any different even if you move the lines to the regulator as the reg is regulating flow throught the T.
At 75/80 mph at 14.9/15.1 afr i get 22 mpg.
The 850 inj have no problem ideling!
Thanks.
Old Aug 18, 2008 | 09:37 AM
Busted7's Avatar
The kit looks nice.
I went with both pumps running becouse if i see an afr problem caused by a pump quiting i will see it sooner on the afr gauge than wide open throttle maybe.
Ive never had fuel over heat problem even in 98 deg.
Something i forgot to mention running the evap line for a return will require that you vent the fuel tank, i vented the fuel cap with a 3/16 drill bit. No problems with odor or spiting do not drill through the plastic screen in the bottom of the cap.
There are other ways to vent the tank this was just my choice, i was in a hurry at the time and have not found a reason to change it yet. I like simple if it works good.
Old Aug 18, 2008 | 09:45 AM
ChrisRX8PR's Avatar
The kit looks nice.
Oh I see, you had to vent the tank, that was my only worry. Oh well, I already have the 1/2" tubing so I will go my original route anyways but thanks for clearing that up.
The fuel system was done by me, no kit, although that would've made it easier, it uses Kg parts fuel rails(RX-8) and a lot of thinking on what fittings to get. It should be pretty fool-proof when I am done with it though
Question: When you ran both pumps, where they both Bosch 044-'s returning through the stock fuel line? How did the pressure behave at idle?
Thanks,
Chris
Old Aug 18, 2008 | 10:04 AM
Busted7's Avatar
No: twin walbros in tank and pressure is solid 43 lbs base.
Old Aug 18, 2008 | 10:06 AM
ChrisRX8PR's Avatar
ok, I see. that is my worry about having both on all the time...it will be trying to return two Bosch 044 fuel pumps through a 5/16" line....I'm thinking it might cause the pressure to spike when at idle....I guess I'll just have to try it to know.... Thanks for the pointers.
Chris
Old Aug 27, 2008 | 06:46 PM
TURSTY's Avatar
The wankel way!!
Hay busted, have you got any pics of how you mounted the two pumps? Did you use one in the factoy location and a bracket to hold to second one next to it?
