My series 4 T2 FC
Old Aug 7, 2008 | 06:45 AM
RX07FC's Avatar
My series 4 T2 FC
Hey guys, from down under
picked this up couple of months ago.
basically, its a 1988 FC S4 T2, with :
- Mild port 13B turbo
-Microtech MtX8 computer with handset
-550cc primary injectors, 1000cc secondaries
- 3 inch mandrel bent exhaust with dual mufflers at the back
-18 inch mesh style wheels 265 rears
-Turbosmart adjustable boost T
Stereo:
- Sony explode headunit
-Alpine Type S 6 inch 3 ways in the rear,
-Alpine Type S 6 inch splits oin the front, with custom mounts i made
-600W Kenwood Dual voice coil sub
-Sony dual/mono block amp for the sub
Car is good, made 260hp on 12psi, cranked her up to 20psi, but screwed my tune up when i hit the handset accidently
plans are bigger turbo, holset HX50 with front mount etc etc..
body has some hail damage which is getting fixed over the next couple of weeks. here is some pics..
[IMG][/IMG]
and
[IMG][/IMG]
wat u all think?
Carlos from dooowwnn under!!
Old Aug 7, 2008 | 06:54 AM
OutCold's Avatar
19" shoes?
Old Aug 7, 2008 | 07:01 AM
RX07FC's Avatar
18s man... look big huh...lol
Carlos
Old Aug 7, 2008 | 07:58 AM
ecko's Avatar
E85 Powered
car still looks very clean and does it drive better than she looks.
Old Aug 7, 2008 | 08:47 AM
t24todd's Avatar
RE_p Rotors
clean car but the stock turbo reaches max efficiency @ 12psi so 20 is pissing in the wind
Old Aug 8, 2008 | 01:18 AM
RX07FC's Avatar
i understand wat max effiency is, so for an FC its 12psi? i was guessing it wuld be more towards 16-18, but fair enough. once i get the holset on it ill throw sum pics up and show it off.
wat psi shuld i get it tuned to? i dont wanna run too high boost cus i only got mazda 2mm seals, cmon rotor nuts u shuld know the answer lol kinda new to the rotary scene, but understanding it slowly..
im thinking maybe 14, with a kick of 18psi here and there (for drags)
Carlos
Old Aug 8, 2008 | 06:41 AM
CyborgRyu's Avatar
Drift FC
12-14psi is it. anything higher is gonna be pushing the same as 12-14psi, or even less hp than you see.
if you want more, get a bigger turbo.
Old Aug 9, 2008 | 06:53 PM
RX07FC's Avatar
well yeh i understand that 10psi from the standard turbo will produce less power than 10psi from a larger turbo due to less air being able to flow. the holset hx50 i have going on it will be running 3 inch cooler piping.
did anyone have to remove their power steering or AC compressor to fit cooler piping? im thinking bout removing my ac compressor or all the ac gear, and have my piping run under there then up round into the plenum.
also is the steering heavy without pwr steering?
Carlos
Old Aug 9, 2008 | 07:59 PM
Boosted11's Avatar
Pistons are gay
Most intercooler kits require you to relocate the battery, and remove a/c. Don't get any kits that require you to remove the bumper support, unless you don't care that its not there.
Old Aug 9, 2008 | 10:48 PM
efb17a's Avatar
Nice car mate, love those 18" shoes. Maybe I'll see it when I'm out that way. I have a mate getting married and I am going to visit him before he moves back here.
Old Aug 10, 2008 | 12:15 AM
KhanArtisT's Avatar
Former FC enthusiast
Looks NICE, very well done.
Old Aug 11, 2008 | 01:57 AM
RX07FC's Avatar
appreciate the comments guys.
got a quote today for all the work, the guy reckons the rear turbo housing is a bit too big and might only come on boost around 4000rpm, which wont be very streetable, but when she does come on boost, hang the *** on
we determined that we would use anything bigger than a 40mm external wastegate also.
This week im buying,
-wastegate
-600x300 cooler core with 3 inch end tanks
-thermo fan 16" and **** off the clutch one
ill prob also remove the A/C ****
will get sum pics of all the gear up soon
Carl
Old Aug 14, 2008 | 04:49 AM
RX07FC's Avatar
NNEEWW SSTTUUFFF!!
here is pics of the new stuff..
thermo fan 16inch
[IMG][/IMG]
for you yanks..
60mm eastegate
[IMG][/IMG]
will have more pics soon. cant wait to get the work done
wat u all think?
Carl
Old Aug 21, 2008 | 02:07 AM
RX07FC's Avatar
no replies??????
Old Aug 21, 2008 | 02:55 AM
SouthSideSlider's Avatar
whats a Turbo V?
sorry i think everyone is drooling over the GTUs in another thread right now. very very nice car i with my S5 looked that good.
Old Aug 21, 2008 | 08:23 AM
ecko's Avatar
E85 Powered
yea the gtu caught evryones attention.
Old Aug 22, 2008 | 03:43 AM
RX07FC's Avatar
wats so special bout them? they are no turbz rnt they?
Old Aug 22, 2008 | 09:46 AM
ecko's Avatar
E85 Powered
well the gtu is different to other models...they come lighter and sportier which would be a better model to have.
Old Aug 22, 2008 | 12:26 PM
DJ Apex's Avatar
nice color
Old Aug 23, 2008 | 04:40 AM
RX07FC's Avatar
got a new bonnet, the one on the car now has major hail damage. the new one i got i sprayed black with a half purple half blue pearl thru it. fitting it tomorow, will get pics of it close up, and shuld make the car on a whole look 100 times better. its not staying black forever, just until i replace passenger guard and door, then rreesspprraayyss
Carl
Old Sep 1, 2008 | 01:21 AM
RX07FC's Avatar
well i got the bonnet painted nd fitted, makes the car look a whole lot more better
now i just need to find a door and front guard then ill have the whole car resprayed woowoo
here is some pics...
[IMG][/IMG]
and
[IMG][/IMG]
sex
Carl
