Microtech need to upgrade ignition. suggestions?
Old Aug 3, 2008 | 03:29 PM
dean23's Avatar
pwned
im runing an ltx-8. i need to upgrade my ignition due to break-up past 9psi.
im a bit on a budget, but i can compromise.
also, from what i understand the ltx series ecu has the ignitors built in, correct? well my trailing STILL dont fire and im starting to believe that the ignitors are toast. is there any way i can bypass the ecu's ignitors to get my trailing to fire?
i need this figured out in the next few weeks cause i cant deal with my shitty mileage and less than optimal performance when i leave for college.
Old Aug 4, 2008 | 04:45 PM
rx72c's Avatar
Top Answer: 1
With no questions asked ignore the trailing completely as their are only small gains having it and get your self some CRANE HI-6 6440 Boxes and lx92 coil packs. i found them cheap at summitracing.com and delivery time is fast.
MOST POWERFUL SPARK YOU WILL EVER SEE I GURANTEE THAT.
If you want your trailing to work change the ignitors. if you dont know how to check if your ignitors are toast pm me and ill run you through it. if you search i have posted it some were here before.
Old Aug 4, 2008 | 07:10 PM
dean23's Avatar
pwned
boxes? do i need one per coil?
these are the two items i found from summit.
http://store.summitracing.com/partde...5&autoview=sku
also, gas mileage is a concern. ill be driving 60 miles a day to school and back. how much will the crane system help?
Old Aug 5, 2008 | 03:38 AM
rx72c's Avatar
Top Answer: 1
one box per leading coil.
Yes they are the correct items.
so 2 of each.
Old Aug 5, 2008 | 05:05 PM
dean23's Avatar
pwned
what other options do i have?
Old Aug 6, 2008 | 04:38 AM
rx72c's Avatar
Top Answer: 1
Ive used m&w.
rubbish in comparison to the crane boxes in my experience.
seen some people use msd.
but personally havnt seen any cdi box that works as well with the microtech as the crane box.
Old Aug 9, 2008 | 10:45 AM
dean23's Avatar
pwned
i was also going to ask about spark plugs. ive been pretty faithful to ngk, but what else is out there? i was looking at halo plugs, but they dont have any specifically made for rx7s
Old Aug 9, 2008 | 06:11 PM
rx72c's Avatar
Top Answer: 1
nope
plugs to get are NGK R7420-11 if your going CDI.
Excellent plugs. RICE RACING recommended them somewere and i recently tried them on heavily boosted pump fuel WI car and they were excellent.
Old Sep 7, 2008 | 03:55 PM
Trots*88TII-AE*'s Avatar
4th string e-armchair QB
I've heard a lot of good things about the NGK R6725-105's too, for a slightly less cold of a plug (more highway commuting friendly), any experience with them???
Old Sep 8, 2008 | 05:20 PM
rx72c's Avatar
Top Answer: 1
The above plug is more a methanol drag plug. dosnt last very long. can use it if you have cdi but on the street in my experience wasnt a very good plug. hence why i changed over.
Old Sep 9, 2008 | 10:32 AM
Broken09's Avatar
I am becoming...
I've got two Crane boxes that I used for a couple years on my car just sitting here. Both work perfectly if you want them let me know.
-Nic
Old Sep 9, 2008 | 10:58 AM
hondahater's Avatar
spending too much money..
that is so true. The first time I tested the spark using this setup it actually scared the bajesus out of me. It looked like draculas claws were coming out of the spark plug and grabbing a hold of the grounding metal it was touching. That ignition setup is truly worth every peny!
how much and where are you finding the R7420-11 sparkplugs? I looked on sparkplugs.com but they didn't have them.
Old Sep 10, 2008 | 11:40 PM
rx72c's Avatar
Top Answer: 1
PM RICE RACING on here on go to ausrotary.com and Pm him their he has alot of sets in stock.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
lnlreaper
Sep 27, 2015 09:59 AM
sinistersam
Sep 13, 2015 07:17 PM
