FD cd Player.
Old Aug 3, 2008 | 01:09 PM
zheka's Avatar
FD cd Player.
Does any know why anytime you insert cd in Bose CD player on FD. it's stays in it for few seconds then comes back out. I though i had bad CD player, so i bought used one from the guy that claims its working fine. try that CD player and it doing something. is the second one dad also. or its some weird reprogramming to CD player required? Any info would be great.
Old Aug 3, 2008 | 02:21 PM
MyRedFD's Avatar
Enter Title Here
Is the disc a cdr or rw? If so, the factory Bose players don't recognize them.
Old Aug 3, 2008 | 09:11 PM
JM1FD's Avatar
My stock Bose player had no problem with most of my CD-Rs but it wouldn't read CD-RWs.
Old Aug 3, 2008 | 09:35 PM
MyRedFD's Avatar
Enter Title Here
Ahh, well I've seen others on here that had the stock Bose that said they weren't compatible with either one. Who knows.
Old Aug 3, 2008 | 10:34 PM
zheka's Avatar
so it's not that CD player is not working, its just that it doesn't read them? and if it wont read them it will spit CD right out? and yes I did try a CD-R
Old Aug 3, 2008 | 10:48 PM
MyRedFD's Avatar
Enter Title Here
It's a possibility. Does it eject right away, or after a few seconds? If it's after a few seconds I would take it that it just can't read the disc so it gives it back. The deck has to spin the disc first to read it so if it can't then it will eject it. If it's right away I would think there is something wrong with the deck itself. Try a few regular cd's too and if it spits them out I'm going to think the deck has something wrong with it. Might just need to be cleaned.
Old Aug 4, 2008 | 05:06 PM
zheka's Avatar
MyRedFD tnx for helping out you seems to be most that cares in helping me out on this thread. Yeah il try other CD's see if it works. Just that I bough another factory cd player (used) and its doing same thing. Just like you said, Insert cd in and about 6-7 second later it ejects it.
Just that most of new Cd players even if they wont read Cd, they will not eject it unlike this factory one.
Old Aug 4, 2008 | 05:29 PM
MyRedFD's Avatar
Enter Title Here
No problem. Most older players won't recognize a cdr or cdrw. There wasn't exactly a certain time that all brands and models could read them as it was an eventual update but I would assume if it's 8 years old or newer it should play them. I'm guessing yours is too old to recognize them. There are plenty of decks out there that are fairly inexpensive but good for the price. I would suggest going that route if you have a bunch of burned discs.
Old Aug 5, 2008 | 05:37 PM
zheka's Avatar
just confirmed my problem today. I used original CD (not copy) and it worked fine. so my original player is working fine also (probably).
I don't have problem going to the aftermarket players, just that i hate to see none stock interior parts.
tnx myredfd for your info. my problem is solved. (poor knowledge of my audio system).
Old Aug 5, 2008 | 10:26 PM
MyRedFD's Avatar
Enter Title Here
Glad to help. I understand some people like to stay stock looking as much as possible. Just sometimes in order to get around a problem you have to go aftermarket.
BoOsTin FD
Interior / Exterior / Audio
Nov 30, 2004 03:21 PM
red_blast
11
Jan 29, 2004 06:01 PM
Jayseven
11
Nov 17, 2003 07:04 PM
ska*utomatic
May 23, 2003 04:52 PM
Tobal
Sep 5, 2001 10:48 PM
