what can i get out of stock fc with meth ?
Old Aug 3, 2008 | 11:07 AM
turbo-111's Avatar
10 pounds sounds so nasty
i have researched on here b4 about meth inj and that one person was able to run 21psi off the stock tmic. i was wondering what can be pushed with a stock fc setup and meth ?
here are the specs of the system im buying.
Kit includes:
- 150+ PSI High Volume Pump
- 2 Quart Reservoir
- 2 Nozzles To Cover a Wide Range of Horsepower
Old Aug 3, 2008 | 11:33 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
You cant run 21lbs on the stock turbo, or anywhere near that for that matter
Old Aug 3, 2008 | 11:48 AM
Turblown's Avatar
Turn up the boost
He didn't say stock turbo, stock top mount. But for the sake of it you usually don't make power past 11psi on the stock turbo. However with meth power increases up to 16psi. I have run as high as 29psi on the stock top mount with meth on a to4. It was a lot better however after taking it off completely and just running a straight pipe. There is a lot of restriction in the stock top mount.
Old Aug 3, 2008 | 12:02 PM
Juiceh's Avatar
Saiga-12 Power!
Sounds to me like he wants to know what a bone stock FC including turbo can do if you just add meth, but he thinks the tmic is limited to 21psi.
Old Aug 3, 2008 | 12:07 PM
When he said stock setup i figured he did infact mean the stocker turbo aswell
Old Aug 3, 2008 | 12:36 PM
turbo-111's Avatar
yes, you and 1Revvin7 pretty much have it right. i have always heard thet 11psi was about the max for the stock turbo i was just wondering if the psi was increased with meth ( i assumed it was probaly was) and i was thinking it was about 14, 15 psi with meth. i was checking to see what my option are till i can save up enough money and get a descent t60-1 or the fam hx35. thanks for all the info peps
msilvia
28
Apr 14, 2016 12:58 PM
morataya
Microtech
Aug 17, 2015 01:04 PM
