Basic Rotary Care??
Basic Rotary Care??
Hey guys im thinking about buying a 91 RX-7 and just want to know the best way to take care of the motor properly to get the maximum life, and performance out of it.
thanks, Matt
thanks, Matt
Change the oil regularly and check the oil level ever few fill-ups as rotary's inject oil into the housings. So if your system is running right you'll lose about a quart of oil every 3,000 miles.
Other than keeping up on tune up's i'd say redline it once a day to keep the carbon away. Seriously.
Try to let her warm up before you go anywhere, don't beat on her before she is totally warmed up, and don't be worried if you use a bit more than a quart in 3,000 miles. The oil usage is dependent on how you drive your car as at more throttle the car will inject more oil.
- Chris
- Chris
ive never really done anything special, these engines last forever provided that you have oil in it and dont overheat.
with a turbo or higher hp na, tuning becomes an issue in reliabilty, but theres no magic trick.
Trending Topics
