Fabrication Post your questions and projects on Fabrication of Interior or Exterior or custom audio and electronics here.
Intercooler piping
Old Jul 28, 2008 | 02:05 AM
jaggermouth's Avatar
Will TIG for 20b
Intercooler piping
I don't have access to a welder or a bender for quite a while, but Im going to need an intercooler set up for my REW FC project.
Would any of you be interested in making some piping? What costs would I be looking at?
Old Jul 28, 2008 | 10:21 AM
Zero R's Avatar
Just in time to die
Some one doing that is going to need someone with your exact setup to make pipes off of. I would get the engine bay done with all but the pipes and see where you stand. You may find you need very little if any work if thought out well enough. Or you may need a ton of cutting and welding.
Old Jul 28, 2008 | 07:39 PM
TitaniumTT's Avatar
I don't think anyone would want to take on a project like that unless they had the car in thier possion or already made an exact replica of yours and still had the pipes or the exact dimensions. I did my piping by mounting the intercooler knowing where I wanted the filters, then cut & welded all the piping together.
Old Jul 28, 2008 | 11:43 PM
Will TIG for 20b
Originally Posted by Zero R
Some one doing that is going to need someone with your exact setup to make pipes of off. I would get the engine bay done with all but the pipes and see where you stand. You may find you need very little if any work if thought out well enough. Or you may need a ton of cutting and welding.
Yeah that sounds like a smart idea.
When the time comes to get pipes, what places would be a good start to have it done? Exhaust shops?
Old Jul 29, 2008 | 02:10 PM
Zero R's Avatar
Just in time to die
Best place will be a shop that does fab work on cars in house. Exhaust shop may work if they weld aluminum for other things or if you plan on using steel IC pipe work.
Ian_D
Oct 14, 2015 12:31 PM
