Old 07-22-08, 11:49 PM   #1
drift monster
about to upgrade 1.x to 2.1
do i have to get a palm device? can i just hook it up to my laptop?
has anyone redone they wiring harness? mine is kind of mangled and i want to the crispy wires like the fuel injectors.
also, is it recomended to get a full sweep tps?
any other advice would be helpful
drift monster is offline   Reply With Quote
Old 07-23-08, 01:11 AM   #2
turbo2ltr
Yes. No.
I haven't.
No.
Dont eat yellow snow.
turbo2ltr is offline   Reply With Quote
Old 07-23-08, 01:23 AM   #3
95nracer
Actual size
95nracer's Avatar
Probably the most straight forward answers I have ever seen. LoL..
You do need a palm to run the 2.1
What do you mean by crispy wires? Do you mean the insulation?
12.1@114
95nracer is offline   Reply With Quote
Old 07-24-08, 10:40 AM   #4
drift monster
the wires are hacked.
PALM zire 71 or SONY Clie PEG-t615C , i can get both with all the accesories for 40 bucks, which is better?
Old 07-24-08, 10:55 AM   #5
turbo2ltr
Id go with the zire.
Old 07-25-08, 03:25 AM   #6
AUGieDogie
AUGieDogie's Avatar
The only thing to worry about the wires being crispy is if it runs now. You won't need to change any wires to get the 2.1 working only for add-ons. The good news is that if you do want to add a wideband or such, it only needs one wire at the cpu and those are usually only messed up by bad AFC installs.
IF your wires are really screwed up at the ecu then find a spare harness online and splice in new connecttors. Thats what I did and it worked great! I am eventually going to re wire my injectors as well, new connectors, and wires to the ecu.
GL
When in doubt.......... Empty your magazine
AUGieDogie is offline   Reply With Quote
ReSpeed brake upgrade - master cylinder upgrade? mactizen 1st Generation Specific (1979-1985) 7 12-02-07 09:01 PM
Single Upgrade & Fuel Upgrade project / now crank with high throttle ?? rx705 3rd Generation Specific (1993-2002) 3 06-02-07 08:42 PM
stock BOV with turbo upgrade? and other upgrade quick questions gcooper9 2nd Generation Specific (1986-1992) 4 02-04-06 10:35 PM
Engine Management Upgrade, ECU upgrade vs. PFC slyez 3rd Generation Specific (1993-2002) 3 05-13-05 10:08 AM
how to upgrade fuel system for to4e sinlge tubo upgrade from XS stallion Single Turbo RX-7's 6 09-19-01 01:37 PM
