Rotary Drag Racing The place to post your racing stories and info
Battery cable crimper??
Old Jul 18, 2008 | 11:20 PM
ultimatejay's Avatar
Need help. What tool are you guys using to crimp large battery cable eyelets on the 1 guage wire? I can't find any tool anywhere for this?
Thanks
Old Jul 18, 2008 | 11:25 PM
13B-RX3's Avatar
7s before paint!!!
We have access to a crimper at our local NAPA store. It is a V block with a punch like device made into it, you just smack the **** out of it with a hammer.
On the cable in my car i crimped with a hydraulic hose crimper
Old Jul 18, 2008 | 11:29 PM
Gohan3rdrift's Avatar
Movie Star
I used a flat head screwdriver and a hammer...
seriously...
Thanks again Allen, I'll try to find one of em.
Old Jul 18, 2008 | 11:33 PM
seriously...
M.I.C.K.E.Y.M.O.U.S.E Thanks for the input and honesty but I wouldn't be able to sleep at night thinking that my battery cable I just smashed with a screwdriver may come loose and short out causing my car to go up in flames and then my house and me and my family.
Old Jul 19, 2008 | 12:44 AM
crispeed's Avatar
'Tuna'
http://www.toolfetch.com/Category--P...ools-cat.shtml
You can modify a bolt cutter to do the same!
Old Jul 19, 2008 | 12:45 AM
crispeed's Avatar
'Tuna'
repost!
Old Jul 19, 2008 | 11:47 AM
Busted7's Avatar
Will work for horsepower
The cable crimper works great, i have silver soildered them and you could lift the car with it!
Old Jul 19, 2008 | 09:36 PM
Thanks, I think that's what I am going to do. Buy two cheap harbor freight cutters and modify them.
Thanks everyone.
Old Jul 24, 2008 | 11:00 PM
Ok here is the solution for all you tight asses. And these days, aren't we all.
I went to harborfreight and bought one 24" cablecutter- $10.99.
got my die grinder with a egg shaped bit and put the cable cutter in a vise with the jaws open. I then slowly closed the jaws on the bit while running to make an even cut on both sides to the correct size that you want. That's it. Instead of buying a $85+ bucks all you need is 11 bucks. Here are some pics.
Attached Thumbnails Battery cable crimper??-battery-boot.jpg   Battery cable crimper??-battery-boot-007.jpg
Old Jul 26, 2008 | 06:05 PM
crispeed's Avatar
'Tuna'
Works nice doesn't it!
Old Jul 26, 2008 | 09:31 PM
Yeah, thanks for the suggestion. Now, all I am waiting for is my 9" to be finished and I will be hitting the strip!
Old Jul 28, 2008 | 09:12 PM
93FDADR's Avatar
I usually just use a bench vice
toplessFC3Sman
Mar 20, 2018 01:54 PM
The1Sun
Sep 18, 2015 07:13 PM
