What puts the car into limp home mode?
Old May 5, 2002 | 05:08 PM
P'cola FD's Avatar
Hamado things my way!
Angry What puts the car into limp home mode?
What will put the car into the limp home mode? I know that a MOP or MAP problem will do it, but what else? I'm asking because just recently, my check engine light came on, and the car seems to be running in the safe mode- cutting out once boost hits and backfiring like crazy. My biggest problem is that it is intermitten, the check engine light will come on and off, and jerk like crazy whenever it does. I checked the codes, but it isn't showing any(and I'm doing right). I need to know what to check for. I have a pettit ecu and an afc. The pressure sensor on the afc reads good, but I disconnected it(while reconnecting the pressure sensor wire) for good measure> I also put my stock ecu in with no change. The TPS seems to be fine, and so does the crank angle sensor. What else should I check?
Old May 6, 2002 | 07:38 AM
P'cola FD's Avatar
Somebody, please help me out here. I need a direction in which to look.
Old May 6, 2002 | 08:39 AM
P'cola FD's Avatar
Thanks Ryan, but here's the deal, I looked in the manual, and it seems to show that only a few things will put it into limp home mode. Problems with the MAP sensor and metering oil pump are a couple, but the thermosensors won't. When the check engine light comes on (in my car) the A/C compressor disegages and the engine stumbles. In neutral, it will rev smoothly until I try to get any boost and then it's like hitting fuel cut. I know my wiring harness is nasty, and if I need to replace it I will, but I don't know if that's the problem. I've been considering buying a haltech just so I don't have to deal with the stock computer's B.S. I just wish it would throw a code for me!
alphawolff
Nov 17, 2015 05:57 PM
LMBTG
Aug 15, 2015 01:43 PM
Marty RE
Aug 13, 2015 11:19 AM
Wolf_
Aug 11, 2015 04:23 PM
