60k Tune up?
Old Jun 30, 2008 | 12:09 AM
SpideyFan6010's Avatar
Parker is my homeboy *)
TX 60k Tune up?
Is there a confirmed list of stuff that should be done every 60,000 miles to ensure you engine lives as long as possible? People tell me to do this and do that but there is no official 60K Tune up list on the forum? If there is could someone redirect me to it cause I can't seem to find it and it isn't under the FAQ's I think this would help a lot of new 7 owners on there way to a good start. Send me stuff that should be done every 60,000 miles and I will make a list and update until everything is covered. If there isn't a 60k tune up list then we should make one.
Thanks for your time.
Old Jun 30, 2008 | 12:46 AM
InsomniacFC's Avatar
Will drive for parts
Dude, it's in the first 10 pages of the Haynes manual. If you don't have one then that would be first on my list.
Anyways, cause i'm bored.....
NOTE:
I: Inspect, and if necessary correct, clean, or replace.
A: Adjust
R: Replace or change
T: Tighten
L: Lubricate
From the owners manual:
  1. drive belts (except the air pump) (I)
  2. engine oil and filter (R)
  3. air filter (R)
  4. spark plugs (R)
  5. cooling system (I)
  6. engine coolant (R)
  7. check the idle (I)
  8. change the fuel filter (R)
  9. inspect the fuel lines (I)
  10. Engine oil warning system (I)
  11. Engine coolant level warning system (I)
  12. brake line hoses and connections (I)
  13. brake fluid (R)
  14. clutch fluid level (I)
  15. brake pedal, clutch pedal, and parking brake (I)
  16. power brake unit and hoses (I)
  17. disc brakes (I)
  18. power steering fluid and lines (I)
  19. steering operations and gear housing (I)
  20. steering linkage, rack guides, and tie rod ends (I)
  21. rack seal boots (I)
  22. front suspension ball joints (I)
  23. front wheel bearings (L)
  24. manual transmission oil (R)
  25. automatic transmission oil (I)
  26. rear axle oil (R)
  27. seat belts, buckles, and anchors (I)
  28. bolts and nuts on chassis and body (T)
  29. drive shaft dust boots (I)
  30. toe control hub and control link (I)
Keywords: 60k 60000 60,000 mile miles tuneup tune-up tune up
Old Jun 30, 2008 | 12:51 AM
TX
NOTE:
A: Adjust
T: Tighten
L: Lubricate
  3. air filter (R)
  4. spark plugs (R)
  13. brake fluid (R)
  17. disc brakes (I)
I don't own a manual but I will defiantly pick one up.
Old Jun 30, 2008 | 12:54 AM
Wicked.
Old Jun 30, 2008 | 01:38 AM
TX
Wicked.
Thanks again for the post
Old Jun 30, 2008 | 02:25 PM
De nada.
Old Jul 1, 2008 | 09:53 AM
TX
Anybody else have anything to add?
Old Jul 1, 2008 | 02:08 PM
Eple's Avatar
Epilepsy
I like pie.
Old Jul 1, 2008 | 04:18 PM
TX
Originally Posted by Eple
I like pie.
Thats nice. Does any1 have anything to add to the 60k Tune up list?
Old Jul 1, 2008 | 06:37 PM
Polishammer's Avatar
Or save your money and go to http://www.teamfc3s.org/main/factory...aintenance.pdf
Amazing how many people do not check FAQ
Old Jul 1, 2008 | 06:55 PM
ALLslowNOshow's Avatar
beer
Old Jul 2, 2008 | 01:18 AM
TX
Sry I found this site outside of the FAQ's after I made this post. I did read the FAQ's I must have missed the site by mistake. My apologies I can't help that I am human and make mistakes. Thank you for posting this.
Old Jul 2, 2008 | 01:19 AM
TX
All the information for a 60k Tune up is posted by Polishammer at the website listed.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
