i recently upgraded to 1600's because i was hitting 90% d/c with 1000's. Ill warn you it doesnt work out very well trying to tune the staging point. since staging is load based now, the secondaries dont come on at a set boost.
right now i have it set for the 550/720 preset, with 20% staging correction taken out above 3k rpm and above 6 psi. It seems to work out ok in 2nd and 3rd gear, no stumbles and fairly consistent AFR during transition. But in 1st gear, it will stumble, probably something to do with it being load based.
It would be great if instead of the rtek staging parameters being an adjustable rpm at a fixed load, it could have both rpm and boost parameters adjustable. it would make tuning larger injectors a little easier
i can send you my new fuel map if you want to see what its like. besides the afm maxing out, staging large secondary injectors is the only limitation i see
