Car wont start hot
Old Jun 23, 2008 | 10:21 PM
Noxi's Avatar
Tech Dweeb
Car wont start hot
my car will start up cold but when its hot it wont start unless I push it
its an 83 rx7 with 12a street port rb heads and exhaust I just rebuilt the carb a couple weeks ago
any ideas?
Old Jun 23, 2008 | 10:38 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
yeah rebuild the engine. Test your compression when hot and u will see what I mean.
Old Jun 23, 2008 | 11:04 PM
orion84gsl's Avatar
My 7 is my girlfriend.
I had this problem when I first bought my 7. Turns out the battery was garbage. Have yours load tested to see if it's the culprit. Good luck.
Old Jun 23, 2008 | 11:23 PM
Noxi's Avatar
Tech Dweeb
I bought a brand new battery
Old Jun 23, 2008 | 11:32 PM
RustyRacer's Avatar
Back on the Road
Have you adjusted the idle?
Old Jun 23, 2008 | 11:41 PM
Noxi's Avatar
Tech Dweeb
i can make it idle fine i dont think thats the problem tho
Old Jun 24, 2008 | 04:12 AM
Paul Loatman's Avatar
The Chartist
My GSL has a hard time starting hot, but it just takes a bit longer to get going, but it does start eventually, sometimes it takes up to 5 times of turning to get it to start but the carb is crap so that could be why. Are you sure it can't start while it's hot? Have you tried multiple times before pushing it?
Old Jun 24, 2008 | 02:16 PM
Noxi's Avatar
Tech Dweeb
I try about 3 times I usualy dont like to put to much load on the battery I dont want to kill it, I will test 5 or 6 times to start it
Old Jun 24, 2008 | 03:29 PM
RustyRacer's Avatar
Back on the Road
Do you have hot start assist?
Old Jun 24, 2008 | 05:51 PM
Hyper4mance2k's Avatar
The Shadetree Project
Rotaries that have hot start issues either have a rich issue, flooding, or low compression...
Old Jun 24, 2008 | 08:07 PM
axle's Avatar
thats also why they have a hot start assist
Old Jun 24, 2008 | 11:48 PM
Noxi's Avatar
Tech Dweeb
no I dont have hot start assist so I hooked up the cable to the hot start assist and had a friend pull the cable while i started it still didnt work
Old Jun 25, 2008 | 11:14 AM
Kentetsu's Avatar
Start by checking your timing. If that's good, then pull the cover off the air cleaner and see if you have fuel pooling up on the butterflies.
Old Jun 25, 2008 | 11:35 AM
The Chartist
Don't know what your problem is then, since you said you rebuilt the carb. My carb is in horrible condition and i need to rectify that, so i don't know what you need to do, maybe your ignition coils or plugs and wires? If all those are new then i wouldn't know, i'm not a mechanic.
dkwasherexd
May 27, 2017 04:51 AM
gtcd
30
Aug 19, 2015 02:44 AM
befarrer
Aug 14, 2015 04:18 PM
ashleymiche
Aug 14, 2015 12:59 PM
