Old 06-23-08, 01:56 PM   #1
SpikeDerailed
Felix Wankel's Bitch
Send a message via AIM to SpikeDerailed
Talking Woot!
Purachased a spare N351 for my '91 vert, and sent it out this morning for the stage 2 setup. I got a call from Mike(I believe was the name) reminding me that they wouldn't be processing any orders from 6/30-7/12 so get it in soon, I was in like at the post office when this happened ^_^ and have it going overnight to harrisburg.
Already have my palm pilot(m515) got off ebay for $35 with shipping and a 1gig SD card for storing logs and have talked to draco performance in huntersville about some time on their awd mustang dyno. Things are looking good.
I have been reading though the .pdf manual for stage 2 and seems all good so far. Yep im happy
Can anyone recommend a good WB o2 setup that works well with the rtek?
Originally Posted by Dinnercoat
You're comparing "stupid forum policies" to the torture and murder of the homeless. Wow.
Originally Posted by CasperIV
If find the two comparable...
SpikeDerailed is offline   Reply With Quote
Old 06-24-08, 03:04 AM   #2
AUGieDogie
AUGieDogie's Avatar
I use the plx in my 87 turbo. With the new ones you don't even neet to use a gauge use plug the sensor into your harness and away you go.
When in doubt.......... Empty your magazine
AUGieDogie is offline   Reply With Quote
Old 06-26-08, 01:53 AM   #3
SpikeDerailed
I would like to have the gauge hooked up so I can see whats going on, along with hooking it up to the ecu for logging.
Old 06-26-08, 02:54 AM   #4
SpikeDerailed
Does you're PLX o2 sensor screw into the factory bung?
Old 06-26-08, 03:41 AM   #5
boost_its_what_for_dinner
RotoriousRx7
boost_its_what_for_dinner's Avatar
yes they all do but you will want to get another bung welded in the downpipe/header since i guess you are n/a?
87 T2 : RR rebuild/SP/JHB jugs : gt35r .82 t4 : 720/1600 : 3"full exhaust : Walboro 255 : big Fmic : KOYO rad./16"e-fan : Greddy Profec b : Apex i bov : uego wb02 : E6X : premix
boost_its_what_for_dinner is offline   Reply With Quote
Old 06-27-08, 01:30 AM   #6
SpikeDerailed
Yea I am unfortunitly n/a. I had mazda compression test the engine and the lowest chamber was 111psi(highest was 118) on a weak battery(bad cell). I cant bring myself to yank it out.
Old 06-27-08, 12:22 PM   #7
7fold
7fold's Avatar
solid numbers im sure you could find someone to buy it at a decent price with proof of those numbers.. that would pay for about 5% of the turbo project tho
87 n/a- CS 2.5 inch header, CS 80mm pre-silencer
CS 80mm cat-back, Custom cold air (for real) intake
lowered 1.5 inches, Emissions Removed
ICW wheels, MSD 6a ignition
E-fan, AC removed.
7fold is offline   Reply With Quote
Old 06-29-08, 12:03 AM   #8
SpikeDerailed
Yea...not yet though. I got a S4 se that isn't far off from a Tii swap though, that is when I get time(**** work).
Old 07-02-08, 09:56 PM   #9
NJGreenBudd
rx-for-my-7
NJGreenBudd's Avatar
The NGK A/Fx is awesome.
I'm using it with the Rtek7 Stage 2.1 and love it, very easy to install and setup with data logging...
It's only like $275.
'87 TII- Rebuilt w/Rtek7 2.1, BNR Stg 1, Profec B Spec 2, 4x720cc, 255lph pump, RB DP w/3" turboback, NGK A/Fx, Stance GR+, VMIC, etc...
NJGreenBudd is offline   Reply With Quote
Old 07-15-08, 11:01 AM   #10
rogrx7
Turbovert done.
rogrx7's Avatar
that wideband is wayyyyyy to close
rogrx7 is offline   Reply With Quote
Old 07-17-08, 03:41 AM   #11
SpikeDerailed
Well my PLX wideband and DM-200 showed up yesterday, now I just gotta find time to start installing.
Greenbudd how much smaller is that wheel than stock? What size is it anyway? Im fat and that factory airbag wheel on the non tilt column aint cutting it.
LA Local Auto X meet AGAIN!!!!! WOOT WOOT recon fd South RX-7 Forum 10 08-01-06 12:22 AM
Tag Renewal Just Came in....Dont Have to worry about emissions this year. Woot Woot!! STR8BALLIN - R Canadian Forum 13 04-09-06 12:17 AM
WOOT Doobie Brothers WOOT pinkfloyd The Lounge 1 11-09-05 02:04 PM
woot woot might buy my uncles fc! Bluem 2nd Generation Specific (1986-1992) 2 06-19-05 08:53 PM
Woot Woot Video Zer0 Cylinder The Lounge 18 05-15-05 04:36 PM
